SOURCE: KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
SOURCE: switching Capacitor to another car
This is a specialized capacitor device. This device is designed to hold and discharge a very high amount of electrical current in a very short time to an audio amplifier as needed during a demand. As with that said, safety is a big issue with any attempt to discharge or transport these devices. That stored current packs a punch if you attempt to dead short it out (not advised, makes huge sparks, could cause damage or injury). You should consult your owners manual concerning your specific equipment. but since you are dealing with only 12-15 volts of electricity, you can just simply easily move it to your new vehicle with no problem, just DO NOT Short it out, or touch the terminals with wet hands when you move and reinstall it. :D
SOURCE: All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
SOURCE: Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
