GE GTDP300EMWS Dryer Logo
A
Anonymous Posted on Feb 04, 2014
Timer handle replace - GE GTDP300EMWS Dryer
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
1helpful
Can you use a plug in timer to switch your storage heater on during the cheap rate electricity
Generally NO.
But...it Depends on amp rating of timer, wattage of water heater, and line voltage.
Look at label on side of heater for watts.
Electric water heater will work on any voltage.
1) Start with 120 Volt outlet::
Volts x amps = watts
Watts divided by volts = amps
Let's say outlet is 120Volts. Lets say water heater is rated 4500 watts.
4500 divided by 120 = 37 amps
There is NO plug-in timer rated for 37 amps.
Let's say water heater is rated 900 watts.
900 divided by 120 volts = 7.5 amps
Yes. The Intermatic HB113 timer will handle up to 8 amps.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
2) 240 Volt outlet
Same calculations as above.
1900 watt element divided by 240 volts = 8 amp.
Yes, the Intermatic HB112 timer will safely handle that element.
3) Here are some water heater timers:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
4) Here are some off-peak water heater ideas.
http://waterheatertimer.org/Off-peak-water-heater-ideas.html
I have lost one of the little plastic pegs on my 24 hour timer.. where can i get replacements?
Only plastic trippers on market are for Intermatic:
http://www.amazon.com/s/?ie=UTF8&keywords=intermatic+timer+trippers&tag=googhydr-20&index=aps&hvadid=5156211581&ref=pd_sl_1b2t69w1k6_b
The reason for this: Low cost of buying new timer.
Trippers plus shipping-handling cost more than most new timers.
Look at timers on following links to find replacement that suits your purpose:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
How do I replace door handle end cap on model JGBP34GEP3AD
The liner on the inside of the door has to come off by removing the two large screws, you can probably just pull the liner back to get to the end cap screw.
2answers
Water won't stop after removing a electronic water timerfrom hose
turn off water ar meter
remove valve or guts fron tap on wall and replace ruber washer
option 2 go to wallmart and buy a mini ball valve screw it on wall facet and turn it off voila it now turns off 3.99 and your grass is no longer a swamp
Jul 25, 2009 • Garden
LER8648LW0 Dryer. Not heating, runs continuously (stops w/ door opened). Timer not advancing. Checked fuse(0 ohms), thermostats (0 ohms) and coil (10 ohms). Timer was at 10-11 K ohms,(high end). So...
One side of the element powers from the timer and the other side from the motor . Remove one wire from the element , and check which wire is not getting 120 V . Trace the wire NOT getting 120V and it will lead either to the timer or the motor , providing that the small t-stat looking piece (thermal cut-off) located close to the top of the heater box , shows continuity . If it does not , then pt # 3392519 is for it and the hi-limit t-stat . If you replace it , then replace both that come in the kit .
Have to change cycle manually
Reason? There shouldn't be one. Seems you're extraordinarily unlucky with timers. Mine's 10yo, never broke. The timer is a standalone part, it's not dependent on any other parts for its longevity. So there can't be any other parts in the washer 'killing' it.
Are you handling it gently? Turn it slowly when setting, don't whip it around.
Top GE Dryers Experts
vince
Axel Gringmuth
Are you a GE Dryer Expert? Answer questions, earn points and help others
