I tried using a line out converter which simply did not work, and i cannot afford a new stereo with RCA outputs and Ipod connectivity. I'm an electrician by trade and can easly make up a new high level plug if only i could get hold of the pin configuration.
SOURCE: PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
