Epson Stylus Sx535wd Logo
t
thumper28022 Posted on Feb 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam The paper feeder keeps jamming no matter what I do. I have tried using different amounts of paper but every time it takes the first page in then jams immediately. Any help or suggestions would be great! Thanks
Lisa Brown
Level 2:
Habit-Forming:
New Friend:
  • Expert 23 Answers
  • Posted on Sep 07, 2017
Lisa Brown
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
23
Questions
Helped
41373
Points
102
The paper jam is a very common issue that occurs in Printers. It may due to improper placement of papers in the printer, bits of paper might get stacked in the printer head, etc. Below are few top steps described by the Epson Printer Tech Support experts to fix these paper jam issues on Epson printers:
  • Turn off the printer.
  • Look for the readout, if any is existing.
  • If the paper is visible, tug it out the top immediately.
  • If the paper is out of place, gently tug the paper out of the printer.
  • Open up the paper tray.
  • Make sure that all the trays are well loaded, but not overloaded, with useless papers.
  • Open up the front as well as top covers of the printer.
  • Pull out the print cartridges gently.
  • Open up any of the back or side covers of the Epson printer.
  • Clean all the dirty parts which is there inside the printer, if necessary.
  • Reinstall all the print cartridges as well as paper trays that were removed, and close all the lid of the printer.
  • Turn on the printer again, if it was turned off.
  • Take some time to allow the printer to warm up if it has a start-up cycle.
  • Check for the printer if it is online.
  • Turning the power off and then turning it on again is necessary to reset the printer once the jam is cleared off completely.
  • Opening up and close the top as well as front cover of the printer is necessary, if it is not yet open it in order for clearing up the paper jam.
  • Push the printer button labeled as "Ready", "Start", or "Go" button to bring it back online.
  • Check for the readout, if any, then it will read "Online" if the printer is online.
L Pfaff
Level 3:
Top Expert:
  • Epson Master 11,573 Answers
  • Posted on Aug 03, 2016
L Pfaff
Epson Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3653328
Points
181716
Epson stylus paper feeder keeps jamming
Printer Help & Support
Level 3:
  • Epson Master 783 Answers
  • Posted on Feb 18, 2014
Epson Master
Level 3:
Answers
783
Questions
0
Helped
286926
Points
1637
Hi Thumper,
Go To Below official Epson Printer Page For Your problem,
Clearing Jammed Paper Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Epson Printer Support
5 Related Answers
A
Anonymous
  • Posted on May 05, 2008
SOURCE: Paper ALWAYS jams!
Check if there are any paper leftovers inside the printer from previous printing jobs and make sure there isn't any strange objects that may have fall down in the paper loading tray.
Also put the printer upside down and move it up and down to see if anything that may have fall in the paper path, can get out of the printer.
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Jan 30, 2009
SOURCE: paper jam epson stylus 5400
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Anonymous
  • 544 Answers
  • Posted on Jun 14, 2009
SOURCE: paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Anonymous
  • 154 Answers
  • Posted on Jun 22, 2010
SOURCE: paper feeds crooked then jams?
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Anonymous
  • Posted on Jul 13, 2010
SOURCE: automatic document feeder pulls paper through only part way
You need to replace the document feeder motor the gears on the motor shaft are split and slipping. New motor is 12.72 at http://www.compassmicro.com/parts2.cfm
Top Epson Office Equipment & Supplies Experts
Rommel Balcita
Grand Canyon Tech
Grand Canyon Tech
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
