Video Game Consoles & Games Logo
Posted on Jan 20, 2018
Error Code: 13 (ProductConfigurationLoadError): There was an error loading the product configuration file 'C:Program FilesNCSoftLauncherConfigDefaultNCPatcherConfigProductsNCLauncherMainNCPatcherProductConfig.xml'. Please make sure the game is properly installed. nc soft launcher please help!!!
5 Related Answers
Anonymous
  • 52 Answers
  • Posted on Sep 27, 2008
SOURCE: msi.chm\msdn
it seems that the file c:\programs\assets\movie\kurt\cs55sfd is corrupt or cannot be copied from the source
Anonymous
  • 22 Answers
  • Posted on Jan 06, 2009
SOURCE: cannot install command and conquer tiberium wars????
try delete it or reinstall. if you can try to download a patch. they are usually some fixes to corrupt files that have been reported for unlucky buyers that have a bad file. so i hope it will work because tiberium wars is a great game =)
Anonymous
  • Posted on Jan 26, 2009
SOURCE: Football manager 2009 xml parsing error
If you have a shortcut on your desktop you can do the following:
  • Right-click on the FM shortcut.
  • Choose "Properties" from the pop-up menu.
  • In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
    "C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
  • Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
Anonymous
  • 285 Answers
  • Posted on Jun 15, 2009
SOURCE: Technical Difficulties
You could try to renistallboth generals and zero hour. If that doesn't help, and you really want to play the game, you could try reinsaling Windows, because that then probably is the problem. I hope this helps, Yannick.
Anonymous
  • Posted on Dec 26, 2009
SOURCE: Problemtic sound deompression sofware for My First Amazing World
Issue "[1058]: The sound decompression software has not been installed properly." Description This is a known issue with the Dorling Kindersley software titles and Windows XP with service pack 1 or higher installed. Solution We have two different patches depending upon the particular software you have. If the first patch does not solve the problem, then please install the second patch.http://support.selectsoft.com/download/DKSP1.exe
http://support.selectsoft.com/download/dk-SP1fix.exe
Top Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
