Mitsubishi MSH09TW Air Conditioner Logo
A
Anonymous Posted on Feb 19, 2014
E21 fault code - Mitsubishi MSH09TW Air Conditioner
Khurshid
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 24, 2018
Khurshid
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3022
Points
Mitsubishi cassete ac code E21 what's the problem
2answers
Error code E21 on Bosch washing machine
F21 (or E21) normally indicates a fault with the motor or the main control board. ... If the error code returns, you have a problem with the motor (most likely carbon brushes), wiring or main control. If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
What is error code e21 on model number EIFLS55IIWO
Your fault code means extended drain time. Clear out the filter connected to the pump and this should correct this issue. This filter is under the outer tub before the drain pump and only accessible from the back of the unit. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
2answers
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Hoval boiler fault code
Possibly, but need to know what fault e21 refers to.
2helpful
Canon DR5020 E21 error
Canon Scanners are reliable. Canon has chosen error codes logically, 'P' os Paper related, 'C' os cover related, 'E' is Engineering Support related.
E21 is Document Motor Trouble. E2 is Separation Motor Trouble. Check of connection and load or you may to replace motor. Try connecting the motor to a different location and if the error is same, probably there is no motor fault, if it changes then it definitely motor fault. As a last thing you may need to change the PCB on the side.
S. Mohan, Chennai, India
Canon DR-5020 Error Code E21
Just saw your problem! 'E21' refers to Document Board Motor Problem' Check if there is any loose contact and if required replace motor.
Top Mitsubishi Heating & Cooling Experts
vince
john h
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
