Mitsubishi WS-65857 65" Rear Projection Television Logo
Posted on Jun 10, 2009
Screen is "bowed" in at top and bottom. tried to adjust convergence but that doesn't work.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1562
Points
7
Try punching the mitsubishi logo... I have that same problem... It seems to be a temporary fix, until I know whats wrong.
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 03, 2008
SOURCE: problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Anonymous
  • 10594 Answers
  • Posted on Dec 13, 2008
SOURCE: ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Anonymous
  • 7 Answers
  • Posted on Mar 22, 2009
SOURCE: Bowing at top and bottom, can't adjust convergence replaced IC
you must have the original toshiba remote control in order to fix this problem,if you check th resistors are ok ,you have to go to the aligment by push and hold mute buttom on the remote control and menu in the front of the tv set,
Anonymous
  • 4234 Answers
  • Posted on May 15, 2009
SOURCE: red convergence will not adjust up or down.
This is a failure of the convergence ICs. This can be as simple as poor solder connections on the pins of the ICs or defective ICs. If you can solder, you can fix this yourself. Update this if you wish to attempt a repair and I'll provide additional details and instructions.
Dan
Anonymous
  • 6784 Answers
  • Posted on May 20, 2009
SOURCE: convergence on bottom half of screen only
Hi, this is convergence board failure. this is the reason for the failed alignment procedure and you will need to replace this failed board in order to restore full functions within the convergence options. i will Post a link to the actual part that you will need to purchase. this is a replacement board board and it can be delivered to your door via UPS.
CLICK FOR YOUR REPLACEMENT BOARD(CONV)
Top Mitsubishi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
