Canon iR 2016i Black and White Copier Logo
A
Anonymous Posted on Mar 03, 2014
How to reset e808 error code - Canon iR 2016i Black and White Copier
Nik Shamsul Nik Mohammad
Level 2:
Sniper:
  • Expert 77 Answers
  • Posted on May 06, 2014
Expert
Level 2:
Sniper:
Answers
77
Questions
0
Helped
39299
Points
158
This error due to your red wire at fixing unit out of position,put back and switch on the macine and the error automatically cleared
I am error E808 ir2018 what nay course that pls
Error E808 on the Canon imageRUNNER IR2018 indicates a problem with the primary charging assembly. The primary charging assembly is a critical component in the printing process, responsible for applying a uniform charge to the drum surface. When this assembly encounters an issue, the printer displays the E808 error code. To troubleshoot and potentially resolve the E808 error, follow these steps:
  1. Power Cycle: Turn off the printer and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary errors.
  2. Check for Paper Jams: Ensure there are no paper jams or obstructions in the paper path, particularly around the primary charging assembly area.
  3. Inspect Primary Charging Assembly: The primary charging assembly might be dirty or worn out. Open the printer's front cover to access the assembly, and check for any visible signs of damage or contamination. If you see any toner or debris on the primary charging unit, carefully clean it using a soft, lint-free cloth.
  4. Reset the Printer: If the error persists, try resetting the printer to clear any internal glitches. Refer to the printer's user manual or Canon's support documentation for instructions on how to perform a factory reset or hard reset.
Canon ir 1024 iF shows E808 code error. How can it be fixed?
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
2helpful
2answers
Juki e code 808 solulation ddl8700-7
hello
regarding error code E808 mostly happened in SC-920 control:
1- check +33 DC volt output for thread trimmer - bac-ktack- presser foot lifter.
2- check CTL board. ( any electronic components damage )
the most reason for E808 coming from CTL board.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
Cairo - Egypt
Canon ir2018 error e808 how to clear
To clear the E808 code unplug the machine for about 10 minutes. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. If you have tried to repair this machine, make sure you have not left the connector unplugged.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/travis_e264b9f3ca4047ae
1helpful
2answers
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
E808 0000 Fixing drive circuit failure
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
38helpful
5answers
I have Canon iR 2016 it show E808 code error
i have canon Ir2016 it give 808 error code can u help me please
1helpful
Canon 2020i fuser error code.
unplug machine from wall for 15min. This will reset the machine.
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
