HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner Logo
A
Anonymous Posted on Mar 16, 2014
Cannot detect allignment page - HP Deskjet 3512 Inkjet Multifunction Printer/Copier/Scanner
Pete Fotheringham
Level 2:
Novelist:
  • HP Expert 175 Answers
  • Posted on Mar 17, 2014
Pete Fotheringham
HP Expert
Level 2:
Novelist:
Answers
175
Questions
Helped
87586
Points
280
Cannot detect alignment page- two possibilities-
1: hen the printer prints the alignment you can physically see the lines and colour shades being printed onto the sheet- this should then be scanned with the electronic eye built onto the carriage assembly- usually one automatic operation- if you can see a good clear image printed ( blocks/lines.boxes) and the printer cannot see the image it stands to reason the electronic eve ( spectrophotometer) is not reading the image correctly or at all, if however there are 'missing' areas of the calibration print then the problem lies with the printing side and I would recommend cleaning/ replacing the printheads as required
How to manually change default page margin for Panasonic DP-2330?
oh my go to printer properties, right click, go to page set up change the settings hit APPLY BAM there ya go
Allignment failed
Defects to align the cartridges tend to happen when the scanner can not detect the page. Check the scanner and see if it is working properly.
Every other picture comes out with blue streak across the top
A manufacturers default of printing an allignment sheet after the jobs been completed. The reasons are to indicate to the user ink conditions that is available when any print after all is observed on the complementary printed page. The functionality of the print allignment page could be disabled by manipulating the printer menu functions. the process may require removing and installing the ink cartriges for the option of allignment to be manipulated.
1helpful
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
After putting a new black and white ink cartridge into the printer, it keeps printing the alighnment sheet everytime I turn the printer on. Ugh! What a waste of ink.
actually it is given in that allign page printout that how to stop this.
but listen the procedure.
after the allignment page is printed just place that allignment page in the scanner .the readable side of the page on the glass.then press OK/ENTER what button present in your printer.
the allignment will start.the printer will read the page.and allignment will get completed.then after u ON the printer it will not give you such problem till u replace the cartridges.
New machine.after inserting cartridges,no alignment page was printed.
you can also print the allignment page from the printer.from the printer properties.by going in to the services option.
there it will be listed .
clean the cartridges.
print a test page.
allign the print cartridges.
you can select the option which you require.
thanks.
HP 6110xi cartridge align under Vista Home Premium
it is necessary to place the allign page in the scanner and then press the enter button and the scanner will read the allign ment page as it will take 2 minutes and then it will display the message allignment complete message then it will become normal as it was .so after u get the allignment page place it in the scanner unit of the printer and then press enter.
Wont print alignment page.
go to the printer properties and then click the services option in it and there are three options self test--- cleaning---and allignment--- click allignment.and it will allign.
for any further queries feel free to ask.
thanks
Allignment
when you insert the new cartages then when the align page will print put it in the scanner and scan it once the align page will be scanning it will not print the align page up to you not change the cartrage
2answers
Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
