Horton Archery Fury 160 Crossbow Logo
A
Anonymous Posted on Mar 16, 2014
What speed energy - Horton Archery Fury 160 Crossbow
Kardoc
Level 3:
Top Expert:
  • Horton Archery Master 7,534 Answers
  • Posted on Jul 02, 2019
Kardoc
Level 3:
Top Expert:
Answers
7534
Questions
0
Helped
2852749
Points
58404
1helpful
What does code P1400 mean for a 2011 Silverado
DTC P1400: Cold Start Emission Reduction Control System
Circuit/System Description
The catalytic converter must be warmed to efficiently reduce the emissions. The cold start strategy is to reduce the amount of time it takes to warm the catalytic converter. During a cold start, the engine idle speed is elevated and spark timing is retarded to allow the catalyst to warm quickly. This diagnostic monitors the following to build an exhaust energy model:
• Engine speed
• Spark advance
• Throttle position
• Engine airflow
• Engine coolant temperature
• Engine runtime
• Park/neutral position
• Vehicle speed
The actual model is then compared to the expected exhaust energy model.
tip
Make Your Pool Green!
Energy Efficiency <i>Make Your Pool Green!</i><br /> Pool owners LOVE green pools. Crazy statement if the "green" you're thinking about is unclean, algae-filled water. But when "green" means eco-friendly, a "green" pool is something homeowners should aspire to have in their yards.<br /> Energy Efficiency - Why? Why should I build or upgrade to an energy efficient pool?<br /> <ul> <li><b>1) Reduce Costs:</b> You'll save money. Energy-efficient pool appliances always pay for themselves in reduced electric bills, and then continue to save money for years to come. By choosing pool equipment such a variable speed pump or pool cover, and by establishing good habits like lowering the pool heater when not in use and proper preventative maintenance, costs to a pool owner can be greatly decreased.</li><br /> <li><b>2) Cuts down on energy waste and saves water:</b> Almost all of a pool's heat loss-about 95 percent-occurs at the surface, mostly through evaporation to the air and radiation to the sky. By using a pool cover to prevent heat and water loss, the amount of chemical water treatment will also be reduced. A multispeed or energy efficient pool pump can also significantly reduce the power consumption of a swimming pool by over 65%.</li><br /> <li><b>3) Tax incentives and rebates:</b> Did you know that some states offer tax incentives and rebates for homeowners that purchase energy efficient pool appliances? Check to see what incentives or rebates are available in your state..</li><br /></ul> Energy Efficiency - How? With a combination of pool products and good preventative maintenance habits, you can improve the heating and energy efficiency of your swimming pool.<br /> <ul> <li><i>Pump Efficiency-</i> You can save energy and maintain a comfortable swimming pool temperature by using a smaller, higher efficiency pump and by operating it less. On average, an energy efficient pump will use 30-45% less energy than that of a standard pump. The difference over a season can be immense. Pumps now come in two-speed, four-speed, and variable-speed models, so you can turn the speed down for regular daily use saving a lot of energy, and use higher settings for more thorough, less frequent cleanings. New energy-efficient pumps also move the water more efficiently for further savings. Since pumps circulate the water to keep it clean, the better they work, the less a filter has to work. <ul> <li>The <a href="http://www.pentairpool.com/pool-pro/products/pumps-inground-intelliflo-vs-3050-vs-svrs-variable-speed-pumps-76.htm">Pentair IntelliFlo&reg;</a> High Performance Pump is the world's smartest swimming pool pump. Its onboard computer and intelligent software automatically calculate and program the minimum flow requirements for every pool task - filtering, heating, cleaning, spa jets, water features and more - to optimize performance and minimize energy use. As functions/tasks change, IntelliFlo&reg; self-adjusts to maintain optimal flow rates for further energy savings.</li><br /> <li>With the <a href="http://www.haywardcanada.com/inground/products/pumps/EcoStar.cfm">Hayward EcoStar</a> family of pumps, money flows back into your pocket. EcoStar is the industry's most energy efficient variable speed pump, thanks to a super-efficient permanent magnet, totally enclosed fan cooled (TEFC) motor and industry leading hydraulic design. Tests prove that EcoStar can save you up to 90% on energy costs compared to ordinary single speed pumps. EcoStar matches pump flow to a pool's needs, versus running at full power 100% of the time. It's fully programmable with a self-contained 24-hour clock and up to 8 custom speed and timer functions that allow EcoStar to manage flow throughout the day. Whether used in new construction or aftermarket applications, EcoStar is the perfect choice.</li><br /> <li>Pentair has a calculator that you can use to <a href="http://www.pentairpool.com/pool-owner/resources/calculators/pool-pump-calc/index.html">calculate your energy savings</a> using an energy efficient pool pump.</li><br /></ul></li> <li><i>Pool Covers-</i> A good pool cover will save energy and water. It can keep the water in your pool an average of 10 degrees warmer, which can cut summertime pool heating costs by up to 90 percent. A cover reduces water and chemical evaporation by up to 70 percent, saving nearly a thousand gallons of water per month. A cover also helps keep your pool clean, which means you'll have to run your filter pump less often, saving even more energy.</li><br /> <li><i>Water temperature efficiency-</i> In addition to a pool cover, there are other ways to help keep the cost of heating your pool to a minimum while you still enjoy a comfortable water temperature. Make use of solar energy by locating your pool in the sunniest part of your yard. If possible, screen it from the cooling, prevailing wind with existing structures such as the house or garage, or add a solidly built fence as a windbreak. The water temperature you desire for your swimming pool not only affects the size of the pool's heater, but also your heating costs if use a gas or heat pump pool heater. Heating your pool with solar energy is by far the most energy-efficient method. If you buy a gas or electric heater, check the yellow-and-black Energy Guide label on the appliance. It shows relative energy-efficiency according to tests by the US Federal Trade Commission (FTC). Pool water temperatures typically range from 78&ordm;F to 82&ordm;F. The energy consumption for each degree rise in temperature will cost 10%-30% more in energy costs, depending on your location. In warmer climates, this percentage is higher because of the relatively low cost of heating a pool at 78&ordm;F.</li><br /> <li><i>Timers-</i> Buy automatic timers for both your pool heater and pump. This will allow you to run them in several short cycles during the day, which is more effective than running them once continuously for several hours a day.</li><br /> <li><i>Preventative Maintenance-</i> Maintain efficient daily operations. Turn down the pool heater when the pool is not in use and maintain appropriate water temperatures when in use (78&deg;-80&deg; for active swimming, 82&deg;-84&deg; for recreational use). Raising the water temperature just 1&deg;F can costs an additional 10 - 30%, depending on your location. Keep a thermometer in the pool to help determine the temperature that is best for your pool and mark the "comfort settings" on the thermostat dial to avoid accidental overheating. Backwash the pool filter only as much as necessary to avoid wasting water and energy and be sure to keep drain systems clear to allow the free flow of water. By far, the most energy efficient lights you can get for the pool are LED or solar powered.</li><br /></ul> Energy Efficiency - Not just for pools! It is also possible to make your spa energy efficient. Portable spas are more energy efficient than in-the-ground spas because they are better insulated and usually have covers. If you have a typical portable spa, your heater will heat water 10 degrees in about 8 hours. If you use your spa once a week, lowering the temperature 3 degrees when not in use will save you approximately 5-10% of your spa heating costs; if you use the spa less often, your savings could be even greater. Don't run the jets unless you are using your spa. The mixture of water and air is great for relaxing the muscles, but it cools the water quickly. Spa covers are important. Be sure to leave the cover on until you are ready to use your spa and replace when you're finished. Remember that the heat that escapes is the heat you must pay to replace.
on Mar 17, 2011 • Pool & Spa
2answers
I have a 400 watt sunforce wind generator that is not spinning a lot and the red light is blinking on it
Check the ball bearings at the axis.when the ball bearings at the axis of the spinning have dust or dirt it turns slow.Clean it or change bearings.
1helpful
I'm going to buy a new motherboard...... i found two interesting motherboards Msi x79 Bigbang xpower2 and msi z97x gaming 5 wich one is better and wich cpu should i take i7 4930k or i7 4790k !!!
I'm a MSI guy myself. I would go with the Z97. As for the processors, I would save the extra $150 to $200 and get the 4790k. Plenty of power, and you save some money on it. Use the left overs to purchase a good set of ram. Intel Core i7 4930K vs 4790K
Has a built-in GPU Yes vs No Somewhat common; A separate graphics adapter is not required Higher clock speed 4 GHz vs 3.4 GHz Around 20% higher clock speed Higher turbo clock speed 4.4 GHz vs 3.9 GHz Around 15% higher turbo clock speed Lower typical power consumption 71.5W vs 105.63W More than 30% lower typical power consumption Better PassMark (Single core) score 2,535 vs 1,995 More than 25% better PassMark (Single core) score Better cinebench r10 32Bit 1-core score 8,785 vs 6,903 More than 25% better cinebench r10 32Bit 1-core score Higher Maximum Operating Temperature 74.04 °C vs 66.8 °C More than 10% higher Maximum Operating Temperature Better performance per dollar 4.97 pt/$ vs 3.93 pt/$ More than 25% better performance per dollar Newer Apr, 2014 vs Jul, 2013 Release date 9 months later Lower annual commercial energy cost 77.09 $/year vs 113.88 $/year More than 30% lower annual commercial energy cost Lower annual home energy cost 21.2 $/year vs 31.32 $/year More than 30% lower annual home energy cost
What is energy ?
Put simply, it is a capacity to do work, which in turn is the moving of something over a distance. So your muscles can generate energy by burning metabolites and pedalling a bicycle.
That is a bit oversimplified though when you consider the different kinds of energy. There is
- potential energy, possessed by something, which can be released. The most obvious example is an elevated object which can fall.
- kinetic energy, such as a speeding car which can knock down a pole
- electric energy, a combination of voltage and current
- nuclear energy, bound up in the atom
and others too
Condenser fan does not come up to full speed.
These Ptac units are advance system that are designed with variable speed motors that modulate in order to save energy, This is normal operation, because starting a motor at a lower speed rather than the conventional high speed will save energy, which translates to saving you money. As the load increases (heat) on the condenser coil, the fan will ramp up accordingly.
Hi I am getting a speed indication message on my washing machine
his washer, the MAH500B, like the other washers in the Neptune line, is a front-load design without an agitator. The result is less wear and tear on clothing and improved cleaning and stain removal. This machine also offers remarkable energy and water savings and meets or exceeds the recent federal Energy Star&#174; guidelines for efficiency. The Neptune boasts an automatic detergent dispenser and a bleach dispenser, ensuring that these additives enter the cycle at the optimum time. It has a large tub that can handle the cleaning of bulky items such as bedspreads and rugs. The tremendous variety of cycles ensures that this unit can handle almost any job. Of the many features included is an automatic water level selector, which saves energy by matching the amount of water to the load size. Additional workhorse features include an infinite-speed motor and infinite-speed combinations. The durable stainless-steel washtub will last a lifetime and will cut down on pilling the surfaces of garments.
3helpful
Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
1helpful
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Top Horton Archery Archery Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Explosive Fireworks
Explosive Fireworks
Are you a Horton Archery Archery Expert? Answer questions, earn points and help others
