Won't start error code f01 keeps coming when I try to start any cycle
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
Central Control Unit
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
SOURCE: F01 and add a garment light on
Check the pump first but you most in likley have a bad circut board. On the front of the washer their is a kick panel. Remove the 3 screws on the bottom and remove it. Taped on the inside is a book of codes and some self diagnostics you can run. This is all your repairman will do and he will order the circut board and charge you more than the washer is worth.
SOURCE: error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
