Cooktops Logo
D
Diane GIbson Posted on Apr 04, 2014
I have a Dacon ECC36 Cook Top, It has a Ceran module Halogen plug in Model EM2LFW. one unit is burnt out on it and I need to replace it Where can i find one?
The model #for the cook top plug in EM2LFW. Where can I buy one or have it fixied ?
5 Related Answers
tarl107
  • Posted on Jun 18, 2008
SOURCE: cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Anonymous
  • 172 Answers
  • Posted on Mar 02, 2009
SOURCE: 3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Anonymous
  • Posted on Mar 09, 2009
SOURCE: spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Anonymous
  • 3 Answers
  • Posted on Mar 16, 2009
SOURCE: jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Anonymous
  • 317 Answers
  • Posted on Jan 03, 2010
SOURCE: Just bought a house and has a schott ceran cook
check the breakers in your electrical panel...its 220volts so there should be 2. if thats not it look under it in the cabinet thare may be a plug..thanks
Top Dacor Cooktops Experts
gerbee gomez
jdthefixer
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
