Tablets & eReaders Logo
A
Adeleke Adejuwon Posted on Apr 05, 2014
How can i flash sony tablet on my pc - Sony Tablets & eReaders
Can i transfer my pictures from the gallery on my tablet to a flash drive
Yes, but it takes several steps to transfer pics from your tablet to a flash drive.
There are two ways of accessing tablet files: 1) wireless access which requires a sync app on your tablet and PC software of the same app type. One such app for sync between Android (any) to/from PC software is Cheetah Sync: http://www.jrtstudio.com/cheetah-sync-android-wireless-sync.
Alternatively, you can use ES File Explorer's Network/LAN/Cloud/FTP functions to share files between your Android phone/tablet and your PC via secure Wifi: http://www.cnet.com/how-to/share-files-between-android-and-windows-with-es-file-explorer/
or 2) wired via the USB charging cable, which I will explain in more detail:
Plug your table to your PC using the Samsung charger cable that doubles as a data transfer cable when you remove the USB plug from the wall charger cube and plug it to the USB port on your PC.
Your PC should read your tablet as an external drive: Open "My Computer" and double-click the tablet drive icon>search your subfolders for your pictures. Highlight your picture files and either copy and paste or drag and drop (different way of copy/paste) to your desktop (or desired location), copies will be transferred but not moved from the tablet unless you "cut and paste" from your table to PC to clear out your tablet and make more space. When done, unplug your tablet cable from the PC. Plug in your flash drive to the available USB port: access the flash drive icon on My Computer. Drag and drop or copy and paste picture files to your flash drive.
My tablet usb will not work
Try plugging in the USB cable between the tablet and the USB port of a PC. The PC should recognise and install the correct driver software.
On the Tablet you need to choose between "debugging" and memory flash disk. Choose the Memory flash disk option on the screen.
The Tablets internal drives will then appear as drives on the PC if successful.
Some PC's cannot install the correct driver software, so you will have to download a generic android one from the Internet.
Have sound but no picture from Netflix on my tablet
You might need to update your flash player plugin on your tablet. Search google for flash player for your tablet model and re-install or update.
Flash player doesnt work
Flash Player the software from Adobe (Adobe Flash Player)? or are you talking about when you stick a Flash Drive (Jump Drive) in the USB Port the system does not recognize it?
Download flash player on my coby tablet 2.1
I think your tablet needs to be updated.
Or try that guy's method.
Android 4.0 Tablet PC
I have a problem with my Sony vaio tablet pc. When ever I turn it on it says "Windows could not complete installation. To install Windows on this computer restart installation.
I dont know this tablet unfortunately ,but a lot of this type of equipment has whats called "embedded" software which means basically the operating system is inside a component(chip) on the motherboard ,usually it can only be flashed with extraneous equipment.
This is in relation to other types of equipment which either include the option to reinstall the os on from the hard drive or stuff with drives so you can re-install from disc.
Embedded software makes this type of equipment small and thin,as opposed to having a drive,advantages are it is shockproof and small.
Im sorry i cant help you any more ---good luck!
Davey snake!
2answers
No cd rom drive
if the tablet pc has a usb port you can copy the contents of the cd to a usb flash drive, plug the flash drive into the tablet pc and run the setup file on the flash drive to install the webcam software to the tablet pc. Another option would be if the tablet pc has internet access go to the webcam manufacturers website and download the drivers and software for the webcam to you tablet pc desktop and install them that way.
Top Sony Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
Marvin
Marvin
David Payne
David Payne
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
