134 error is led head missing , the fault is either ( if your lucky) the k led ribbon cable has become unseated or the k ribbon pins are damaged (you can trim them with scissors.
Alternatively more often than not someone has nicked the led bar off and tried to put the cable back in without turning the printer off blowing the fuse on the maintenance board. The holders for that model are prone to cracking also.
SOURCE: my OKI B4600 is displaying
My solution was even easier:
1. Turn the printer off
2. Remove the cartridge from the printer
3. Turn it on
4. Insert the same cartridge again
That's it!
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
