SOURCE: error code AF Whirlpool cabrio dryer
Found the source (it was NOT in my version of the manual)
It is due to low air flow
Here is a direct link to an FAQ on Whirlpool's site:
http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=1509&p_created=1181841464&p_sid=M2mfJcVi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9Niw2JnBfcHJvZHM9MTgzLDI0NCZwX2NhdHM9JnBfcHY9Mi4yNDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb2Rl&p_li=&p_topview=1
You can also enter your specific model number to here to get an updated manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WED6400SW1&siteCd=WHRCOM
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
SOURCE: AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF
Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Testimonial: "Thanks so much!"
SOURCE: the dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
