Plumbing Logo
H
Heather L Evert Posted on Apr 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with pump?
Replaced 1/2 HP shallow well jet pump that rusted out with Everbilt brand, similar specs, not sure if it is working correctly b/c pressure does not go above 15 psi when primed, so no water coming out of faucets in the house
Joel Friedenberg
Level 3:
  • Master 1,114 Answers
  • Posted on Apr 19, 2014
Joel Friedenberg
Master
Level 3:
Answers
1114
Questions
0
Helped
450389
Points
3273
The pump pressure switch should be checked to see what the ON-OFF pressure is set at. Typically the pressure switch is set for 20-40 psi, or 30-50 psi. The pressure tank should be purged as well. With the pump OFF, and the tank drained of water, the air valve on the tank should read approximately 2 psi below the "on pressure". So if the system operates at 20-40, the tank should be pre-charged to 18 psi. If water escapes from the air valve, the internal bladder in the tank is ruptured, and the tank needs to be replaced. A tire air gauge is used to measure the pressure in the tank after the water is emptied from the tank.. A tire air pump or a compressor is used to charge the tank. if a compressor is used, be careful not to over-inflate the tank, as this may cuase the bladder to rupture.
5 Related Answers
Anonymous
  • 126 Answers
  • Posted on May 17, 2010
SOURCE: Shallow Water Jet pump will not start
on the pressure switch are the points closed if not its not asking for water.that flat plat under the two screws with springs on them,push down on the plate that will close the points then figure out why its not closing
Testimonial: "That was exactly the problem, the pressure switch had to be replaced and it now works fine"
agent91
Ned White
  • 2100 Answers
  • Posted on Sep 24, 2010
SOURCE: 1/3 hp shallow well jet pump (mastercraft brand).
I don't think the power shortage had anything to do with the pump, I think it is the impeller or a gasket, or both. It is hard to say, a pump like that should **** dry and pull water right in.If you put your hand over the end of the pipe, it should make a mark like an octopus on your hand. I would take off the impeller, look for trouble, and replace 3 or 4 parts in there , you should have water. Hope this helps.
Wayne Holden
  • 512 Answers
  • Posted on Sep 16, 2012
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Wayne Holden
  • 512 Answers
  • Posted on Oct 07, 2012
SOURCE: Have installed a new 1/2 hp jet pump for shallow well. Everything is new including the WellMate Tank WM6. I prime the pump, turn on the power and the most psi I get is 15 or 17 psi. No leaks. Cut
No response.
Wayne Holden
  • 512 Answers
  • Posted on Oct 21, 2012
SOURCE: I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Top Utilitech Plumbing Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
