Sony HDE1/B 1TB External USB Hard Drive Standard Logo
Marcelo Pellegrini Posted on Apr 16, 2014
Error code 0
Trying to back up some files I have got error code 0 message
  • Kaleb Hawkins Apr 18, 2014
    Hi Marcelo Pellegrini, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Does the error code give you any other information?
    What data are you trying to move?
    Is it encrypted or restricted with permissions?
    Do you have rights to copy that data?
    What operating system are you using?
    What is the medium you are trying to backup the files to?
Laura Bingham
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 09, 2014
Laura Bingham
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1012
Points
When I get trouble with my external or flash drive I'd rather never take risks, so I always get all my files offf the offending drive and just use the Disk Utility, and format the drive. Most problems get solved doing this.
Budhutondu
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 08, 2014
Budhutondu
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
4800
Points
6
Hey Marcelo If you r trying to backup the data with windows Backup System then Check if the Data is restricted or not. If its restricted then try to login through the Administrator rights and try to do.
And if you simply trying to copy and unable to do that then check if u have third party application installed for copying (eg: teracopy or so). If u do have installed then try unintalling that and proceed. Best Of Luck
Ashwanb
Level 1:
New Friend:
  • Contributor 8 Answers
Ashwanb
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
2969
Points
19
I had the similar problem when I tired it. Usually the backup is successful but would have ended up skipping some locations because it could not find them. Most of them would backup Pictures, Music, Documents, and Videos through user libraries. Since you have changed the location of these folders, the libraries won't recognize them unless you navigate to the corresponding library through the Explorer UI, i.e., for example, to navigate to the Documents library, click on the Windows icon and click on "Documents" to the top right. Can you make sure you navigate to each library at least once? Once you do that, the right locations will be updated and backup will start backing up the new locations. Try this out and hope it works for you as it did in my case.
Chris Eltringham
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 24 Answers
  • Posted on May 07, 2014
Chris Eltringham
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
24
Questions
0
Helped
6794
Points
72
I would bet money that the destination drive (sony 1 TB) is formatted as FAT32 versus NTFS. I believe there is a 4 GB limitation on size to destination device given the cluster-size limitations of Fat32. One thing you "could do" is split files into smaller chunks, then copy to destination drive.
IF 1 TB drive is empty, try and reformat 1 TB disk to NTFS, recopy file in native format and you "should" be OK.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
