Computers & Internet Logo
A
Anonymous Posted on Apr 18, 2014
Dir 618 configure as a bridge router
Neil Bhisma
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Nov 21, 2018
Neil Bhisma
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
0
Helped
3343
Points
46
If you are facing issue while using Dir 618 configure as a bridge router then i recommend you to once read this blog to get understand the proper concept to use it : https://www.routertechnicalsupportnumbers.com/blog/fix-invalid-wi-fi-ip-configuration-issue-on-windows-10/
5 Related Answers
Anonymous
  • 667 Answers
  • Posted on May 31, 2008
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Anonymous
  • 108 Answers
  • Posted on Jan 16, 2009
SOURCE: RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Anonymous
  • 167 Answers
  • Posted on Mar 08, 2009
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Anonymous
  • Posted on Nov 26, 2009
SOURCE: Hi I cant configure my router D-link DIR-300
This definitely worked for me. To find out your computer's MAC address, just go to start, then click run, then type 'CMD'. When prompted, type 'ipconfig/all'. Find your ethernet adapter local area network connection, and underneath you will find a lablel titled Physical Address. This is your MAC address and should consist of 6 pairs of number/letter combinations. Then connect your computer to the modem, eithe wirelessly or directly and point your browser to 192.168.0.1. Under Setup click Internet Setup and then click Manual Internet Connection Setup. Under Internet Connection Type, select Dynamic IP (DHCP), then under MAC address, type in the MAC address of your computer. Click Save Settings and Presto! It worked for me.
Anonymous
  • Posted on Feb 18, 2010
SOURCE: how can i configure my d link dir 300 on my
start - run- type in cmd- enter- type in ipconfig /all will show router address should be 168.192.1.1
open internet explorer and type that # in the address bar
should connect with router
leave password blank or type in password for the password
enter the router setup and configure router to your preferance
Top D-Link Computers & Internet Experts
Narseman
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
