Exercise & Fitness Logo
A
Anonymous Posted on Apr 18, 2014
Error code E44 - Keys Fitness Exercise & Fitness
1 Related Answer
ka4iup
ka4iup
  • 4062 Answers
  • Posted on Mar 03, 2015
SOURCE: bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
EWF 1704 erro 41
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
E41 - Door open
Possible causes:
Dado
My zanussi washer is coming up with error code 40 anyone no what it is
Dado
How to do with E40 code of Electrolux EWF 1074?
programme):
E41 - Door open
Possible causes:
Dado
What does e44 means
E44 does mean "door interlock sensor faulty".
Electronics does not recognize the state of door interlock and it should be replaced. This is failures of the sensing line on the PCB which doesn't recognizes close or open state of door interlock.
Dado
Bosch avantixx 8 waq error code e44
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
2answers
Fix e44 error
drain pump or hose filter clogged
E44 = ?
Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
Top Keys Fitness Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
