Exercise & Fitness Logo
Posted on Jun 20, 2009
E1 error code
My Lifespan treadmill is showing an E1 error code. What would cause this?
  • Russ W
    Russ W Oct 09, 2014
    If the belt moves for a few seconds, then it may be a sensor issue - If it does not move at all, chances are the circuit board or the motor are bad. Usually, the walking belt is the root cause of those failures.
  • Rosamond Gianutsos
    Rosamond Gianutsos Feb 04, 2018
    My code E cleared after I vacuumed and blew all the dust out of the motor area. Step 1: take off the cover. Step 2: suck Step 3: blow Step 4: suck again. Problem solved.
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
91859
Points
78
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Russ W
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 09, 2014
Russ W
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12180
Points
If the belt moves for a few seconds before the E1, then the sensor may be out of alignment or not working. If the belt does not move at all, then the motor or circuit board (MCB) are probably bad. The walking belt is frequently the root cause of the problem.
1 Related Answer
Anonymous
  • Posted on Mar 21, 2010
SOURCE: my Lifespan treadmill is showing an E1 error code.
my lifespan treadmill has an error code e1
Top Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
