Siemens WK14D320GB Integrated Washer Dryer, 6kg Wash/4kg Dry Load, B Energy Rating, 1400rpm Spin Logo
A
Alistair Posted on Apr 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code E13
What is this error code?
Sam
Level 3:
  • Siemens Master 3,247 Answers
  • Posted on Apr 26, 2014
Sam
Siemens Master
Level 3:
Answers
3247
Questions
0
Helped
1329674
Points
10379
This error appears to be linked to the door lock but is not described in the user manual.
To find replacement door lock refer to item 202 on the diagrams at this site
http://www.siemens-home.com/ie/store/spareparts/Automaticwasherdryer/WK14D320GB/01
2answers
Reebok treadmill e13 error message
f the E13 error code is still showing after restarting your treadmill, check to ensure that the wiring between the AC motor drive and motor cables is securely connected. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
What is the problem when there is an error message of e13 and e13?
Hello friend, that's a great question!
Based off what you have provided your Frigidaire oven is displaying an error code of "E13" and you would like to know what is causing this problem. The error code "E13" stands for a bad EEPROM (Erasable Programmable Read Only Memory) and this could be an issue with the UIB (User Interface Board). This electrical component may need to be replaced however this is not a simple DIY job. I would recommend speaking with a professional technician for proper diagnosis and repairs. This will prevent you from making unnecessary part purchases. -Matt
2answers
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Top Siemens Dishwashers Experts
Paul Bade
vince
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
