There are many aspects that you can edit the photo, including color, clarity, composition, blemishes, etc. Since there are so many steps, here are some simple tips.
Method 1: For this aim, you need to make use of the Brightness/Contrast sliders to get dark, complete blacks and vivid whites. Distinct differences between your darkest areas and your lightest areas can make your photos more compelling. To add contrast is always the first edit you shall use to make your pictures more professional.
Method 2: You can also increase the saturation of a photo to make the colors more vibrant and eye-popping.
Method 3: When the whole thing is tinted the wrong color, you can edit the photo's hue to correct it.
Method 4: You are able to take advantage of the "Shadows/Highlights" settings to remove any overly bright areas and weaken dark shadows in Photoshop.
Method 5: The Sharpen filter can also be employed to combat semi-blurry or out of focus shots.
Method 6: It is also sensible for you to shrink very blurry or lower-quality images to minimize the problem.
If you still think that the steps of Photoshop are too complicated, you can turn to AI photo enhancer. Here I found a post including several recommendations for help: 10 Best AI Photo Enhancers
I want to edit my photo but i don't know how to open the cs2 adobephotoshop after finished installed..??
There are tutorials inside the program, go to Help menu, there is a choice "How to fix and enhance photo", with many choices of problem.
By the way, the fastest and easiest I used to do to edit is like this: 1. open the photo in photoshop (File --> open)
2. Go to menu "Image" --> Adjustment.
3. Click "auto contrast" to make more contrast, or "auto level" or "auto color". Just try.
If you are familiar already, then you can go on with setting by yourself the contrast, the level or the color balance. All choices are there.
Try it!! If you have spesific problem, post it so we can help you.
Image ready is basically a web desing program for designing web pages and web base graphics GIF'S etc
SOURCE: adobe photoshop
try this link http://72.14.235.104/search?q=cache:Dknkr8yiIVYJ:simplephotoshop.com/photoshop_tools/index.htm+photoshop+tools&hl=tl&ct=clnk&cd=1&gl=ph
SOURCE: can i revert a photo edited on adobe photoshop?
Once the edited image has been saved, the original image gets over written and there is usually no way to go back to the un-edited version.
If you have the original source file, you can restore it to your hard drive. An example of this would be copying a picture from your digital camera to your hard drive again.
You can also retrieve the original file if you've used Windows Backup or some other backup program to save a copy of selected files.
how can i edit photos
i am trying to edit a photo in cs2 photoshop but i have no idea how to do it. does anyone know if there is a free get started tutorial?
meeh
