Samsung DV218AEW Electric Dryer Logo
A
Anonymous Posted on May 10, 2017
I have a Samsung Dryer (DV218AEB/XAA) and it is not providing heat. I recently had the laundry room painted, so I needed to move the dryer away from the wall...the next time I went to use it, it wouldn't dry the clothiers. The dryer does still run however and it puts out cool air, it just doesn't dry the clothes. I don't want to call out a repairman, if I can fix it myself. Is it possible for me to replace the Heater, Thermostat 2 and Thermostat 3? Or how can I figure out which one might be bad? Craig
Lawrence Oravetz
Level 3:
  • Samsung Master 10,558 Answers
  • Posted on May 10, 2017
Lawrence Oravetz
Samsung Master
Level 3:
Answers
10558
Questions
Helped
2776347
Points
29285
Check the circuit breaker for the dryer. There are 2 of them side by side with their handles joined. Sometimes one will trip but not the other. This stops the heating element but not the rest of the dryer.
3 Related Answers
Anonymous
  • 20 Answers
  • Posted on May 23, 2010
SOURCE: I have a Samsung DV218AEB dryer while on sensor
check its thermistor / sensor.
Anonymous
  • Posted on Sep 18, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Anonymous
  • 43501 Answers
  • Posted on Sep 05, 2011
SOURCE: i have a samsung dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Top Samsung Dryers Experts
gerbee gomez
Paul Bade
vince
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
