KitchenAid KECD806R 30" Electric Cooktop, 4 Elements, Tri/Dual Ring Elements, Infinite Heat Control Logo
I
Ian Hatchell Posted on May 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace an element
Center element of the triple hot plate is not working
Lyndsay Sawler
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 118 Answers
  • Posted on Jun 17, 2014
Lyndsay Sawler
Expert
Level 2:
Cheetah:
Answers
118
Questions
0
Helped
21336
Points
158
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
Had hob for 18months no problems, now two hotplates wont work & today the child lock light is on & nothing else will work, nothing.
remove the child lock setting and the remainder will work
those hot plates that were not working may need new switches, thermostats or replacement elements
call an accredited appliance electrician to get it all working again
Jun 13, 2015 • Cooktops
2 Hot Plates won`t work
If it's a gas buner usually the pilot light tube is clogged. If it's electric either the switch or the electric element isdefective. Did they both go out at the same time?
Mar 12, 2015 • Cooktops
My neff helectric hob two of the plates are not working
Sounds like the heating elements burnt out.
Dec 12, 2011 • Cooktops
The double hot plate only works in the center ring, and cannot be turned off except from the wall
I note this cooktop came with a 2 year warranty.
All of the elements are controlled by item 16 of this manual:
http://spares.bigwarehouse.com.au/file.php?document_id=6100
You will have to click on your model number to see it and probably have to enlarge the view.
The part number is 532037 but crosses to 533023 on several websites and sources.
If your having to pull the wall plug to shut it off this is the most probable failure.
Expensive part but most likely what it will take to correct your problem.
Thanks for choosing FixYa.
Kelly
Triple Element does not burn on single mode.
I ordered a replacement part from Sears Direct and used their schematic for a guide.
Chef Supreme Co-ordinate Series Ser. No.: 2004434294 Manuf. No.: 091E11SE1 Sales No.: RETSZW Hot plate not working & suspect bad element or thermostat? 1. The element is not an exposed coil, but rather...
this could be a 220 v unit and one side of the lines is out . ck your power at the breaker and at the cook top . if power is ok I would think it's the control sw . and not the plate .. you will need a volt /ohm meter to test . whirl / g e / frigidair / have genric switches that should replace yours .. hope this will help mm
Dec 03, 2009 • Cooktops
3helpful
3answers
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 • Cooktops
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Top KitchenAid Cooktops Experts
vince
john h
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
