Electrolux EW1000i Front Load Washer Logo
A
Anonymous Posted on May 31, 2014
What is error code e13 - Electrolux EW1000i Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Jun 02, 2014
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1495608
Points
5908
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
What is the problem when there is an error message of e13 and e13?
Hello friend, that's a great question!
Based off what you have provided your Frigidaire oven is displaying an error code of "E13" and you would like to know what is causing this problem. The error code "E13" stands for a bad EEPROM (Erasable Programmable Read Only Memory) and this could be an issue with the UIB (User Interface Board). This electrical component may need to be replaced however this is not a simple DIY job. I would recommend speaking with a professional technician for proper diagnosis and repairs. This will prevent you from making unnecessary part purchases. -Matt
2answers
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
3helpful
2answers
E13
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
Here the tips... support/t7599677-error_code_13
Top Electrolux Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
