Panasonic PT-60LCX64 Television Logo
A
Anonymous Posted on Jun 08, 2014
How do i reset without using the remot
I changed the lamp and the temperature lights blink
5 Related Answers
Anonymous
  • 927 Answers
  • Posted on Jan 02, 2010
SOURCE: I have a PT-44LCX65 and replaced lamp accordingly
Howdy,
No, you must have the Remote.
Sorry, big IRISH.
Anonymous
  • 39 Answers
  • Posted on Feb 18, 2010
SOURCE: I need to reset lamp using my remote for my remote
could be getting to hot clean vent holes move back from wall a little bit.lamp may need replacing.try removing and reinstalling lamp
Paul Bade
  • 1849 Answers
  • Posted on Oct 16, 2010
SOURCE: replaced bulb last nite, green
Many projectors use a lamp hour timer for predicting bulb life so they can give you fair warning of impending failure. Since a bulb may be removed and reinstalled because it is still working or another used lamp installed, the timer is not automatically reset to zero when the lamp is replaced. I surmise your set is complaining because the timer was not reset or the time verified when you changed the bulb.
To fix the problem, buy or borrow a remote control; a universal remote control with a menu button may work. (If you borrow a universal remote from a friend, be sure to record the code for your friend's TV first so you can set it back before returning it.)
You could probably get back into the timer reset menu by removing the new lamp and reinstalling it. Caution: follow the directions on page 68 of the user's manual or the sheet that came with the bulb - let the set cool for an hour first, unplug, and wear gloves when handling the bulb since skin oil can cause discoloration and possibly an explosion when the bulb gets hot. You can download the user's manual from Panasonic's support page for this set.
If you can edit the timer hours instead of just resetting, you may want to set it for the number of hours the new bulb has been used.
It is likely that you can get into the lamp timer menu if the set is in service mode, but the user's manual doesn't tell how to get there (I don't have that info either - it's in the service manual, which may be available online from a third party for a price). Usually it is something like holding a volume or channel button on the front of the TV while turning it on with the remote control. After that you need the code to switch to the timer menu. If you have problems getting into the timer menu, ask your dealer's service department or try calling the Panasonic help line listed on the bottom of page 68: 1-888-VIEW PTV(843-9788).
Anonymous
  • 1476 Answers
  • Posted on Jun 24, 2011
SOURCE: i change tv lamp gren
alcneutron,
See my tip at http://www.fixya.com/support/r8036688-lamp_reset_procedure_panasonic_tvs for the proper reset procedure.
Thanks for using FixYa and for the great rating.
hardrocko
Anonymous
  • 14553 Answers
  • Posted on Mar 26, 2012
SOURCE: can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Top Panasonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
