This means that your evaporator drain pan is plugged. Get on the roof and lay down next to the air conditioner. On the bottom of the unit about 2/3 of the way towards the front, you will see two white nipples sticking down through the base of the AC. These are the drain ports for the evaporator tray. You need to take a long pick or something similar and clean the holes out. It does not hurt to open them up a little to prevent this from happening in the future. If you can't get to them or cant reach them, the ac will have to be removed from its mount and lifted up to gain access.
Hope this helps,
Jeff
