Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
j
john schneider Posted on Jul 06, 2014
Bosch long cycle time - Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Bosch SHE4AMUC/05 will only run correctly after running quick cycle.
Here's some ideas.......
https://readytodiy.com/bosch-dishwasher-not-completing-full-cycle-or-stops-mid-cycle-0051/
2helpful
3answers
Bosch dishwasher starts, pumps, stops and says it's clean
Here is what I found that makes my bosch dishwasher come on. It has the same problems as the OP. I pick the cycle I want press start. The DW will sound like it's trying to drain. I let it run that cycle which takes about 30 seconds. It then starts another cycle that sounds different from the first and when it stops I turn the DW off and then back on, it resets and then it starts the wash cycle. I've done this twice and it has worked both times. I do not know what is causing this but it's better then what I had to do to get it to reset.
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
When my bosch washing machine is during the cycle
clean filter at the bottom there should be a plastic flap at the bottom at the front of the machine wash it out and then put a wash on with nothing in it on a 95 wash.
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Bosch built in dishwasher shu4302uc The dishwasher appears to run through the cycle but the cycle takes over three hours. When the cycle finally finishes the dishes are not completely dry. Is there a way...
There are no adjustments for cycle timing. What does affect timing is temperature of the water coming into the DW. The hotter your supply water, the shorter the time to cycle, BUT if your water is too hot, the cycle time may become too short to light the NSF 'Sanitize' indicator. But since the cycle is taking so long, this is an indication that the DW's water heater is not heating the water hot enough to advance the countdown timer in a timely manner. The control logic is waiting for the temp to come up to an appropriate level to ensure adequate washing, rinsing or drying times. Likely your display is showing '1' for a long time as a symptom of this problem, as well.  - This link http://www.applianceaid.com/boschDW.html has procedures to run self-tests on various Bosch models. I suspect that you can confirm a 'heater fault' on your unit by running the self-test.  - This problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. If you have a Torx driver, soldering iron & bit of solder, you can effect a repair yourself in about an hour. Otherwise, a replacement control board is required.
If you'd like to attempt replacing the control board yourself, refer to this link for part & DIY information. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
- Else, place a service call to the tech of your choice.
1helpful
2answers
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
