Baby Gear Logo
A
Anonymous Posted on Jul 08, 2014
How to fold stroller - Chicco Baby Gear
Dorel UK
Level 3:
  • Chicco Master 1,637 Answers
  • Posted on Nov 16, 2014
Dorel UK
Chicco Master
Level 3:
Answers
1637
Questions
0
Helped
466995
Points
2410
Hi
We would recommend you contact Chicco for assistance
http://www.chicco.co.uk/
5 Related Answers
lbloom
  • Posted on Jun 08, 2008
SOURCE: Graco Quattro Tour Duo Stroller won't fold up
I called customer service at Graco and explained the problem, asked for a fix. The rep said the part is not replaceable and told me to send the stroller back to them for 'evaluation and/or replacement'.  They will pay to FedEx it back to them this week. So that is where it stands.
Thank you very much for your site and offering a chance to put the problem out there.
Anonymous
  • Posted on Sep 27, 2008
SOURCE: folding graco stroller
how to fix the strooles directions
Anonymous
  • Posted on Sep 22, 2009
SOURCE: fold stroller
Not sure how different this one is to ours but we have an older Dreamer Design double stroller and down by the front wheel there are two black plastic clips that you pull upwards while at the same time pushing two small depressable "buttons" that are in line with the main bars coming down towards the front wheel... once that's done you lift and push backwards at the same time, the whole stroller frame will move backwards (oh brake has to be on) and then once those main bars are free you can pull the frame towards you and then double it over back on itself...the rear wheels pull out by pushing the centre button and pulling on the wheel and they you're able to put it just about anywhere...hope that helps...Rob
Anonymous
  • 14 Answers
  • Posted on Sep 29, 2009
SOURCE: How to fold the Graco Stroller 6001BCL1
Take the carrier off by raising the handle and then lifting the handle with one hand as you pull the red handle on the back of the carrier with the other hand. Set the carrier aside and stand behind the stroller. There should be 2 matching plastic 'things' on either side of the stroller, just under the rubber handle. Put your thumbs on the rubber handle and your first 2 fingers on those plastic pieces. Pull those plastic pieces up with your 2 fingers and the stroller will collapse. I hope this helps!
Anonymous
  • Posted on Mar 18, 2013
SOURCE: Stroller stuck and can't be folded
I had the same problem with mine. What I had to do was lift the Adjuster for the backrest while doing that pull the back rest all the way down ( like if baby was laying straight not at a angle) and then pull the two hand hooks and then fold down.
The chicco bravo 2 stroller wont fold
Bravo! For a Removable Seat
The stroller seat and backrest detach easily in one piece, along with the canopy, leaving behind a lightweight frame carrier for the car seat. It's just as easy to reattach so older babies can switch between car seat and stroller.
Bravo! For a Smart Fold
When it's time to close the stroller, the seat cushion lifts to expose a fold handle. The handle engages easily with one hand, activating the fold and simultaneously rotating the front wheels inward to keep the stroller standing for easier maneuvering and storage. Once the stroller is closed, the fold handle doubles as a carry handle.
2answers
How do I fold a Baby Jogger II 15
Baby Jogger's patented Quick-Fold Technology, this stroller is the only in-line stroller to fold flat in one simple step. Just pull the clearly marked "FOLD" handle and the stroller or jogger collapses into an easily loadable and storable unit. This is quite possibly the easiest fold on the market today.
Source:http://www.lussobaby.ca/jogging-strollers--C625-4491.htm
Stroller will not fold
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
We can't get the stroller to fold correctly, it worked once but we cannot get it to fold again.
I can't get my First Years Wave stroller to fold close. I have handle positioned down along with back wheels. Then slide red button, pull on handle/lever thing, but it doesn't fold the legs down. HELP PLEASE!
2helpful
2answers
How do i fold down my baby jogger twinner ii?
place both hands down each side of handle(side of stroller ) pull both hands up at the same time and stroller will fold toward you .
4helpful
Cannot figure out how to fold the stroller back down
if you pull up both sides of the stroller handle you will find the stroller to fold toward you.
put your hands on the handle at the sides of your stroller pull up and the stroller will fold towars you.
Folding the stroller
There are two latches/triggers. one on each side, under the handle bar behind the canopy. pull up on these and the stroller will fold down.
Need instructions on hold to fold my stroller
This is designed for folding with one hand. On the handle there is a red grip. Below the grip there is a button. While pushing this button, turn the red grip clockwise and push down. The stroller will fold. -Vish
Top Chicco Baby Gear Experts
Rommel Balcita
ADMIN Andrew
ADMIN Andrew
Nikole Brown
Nikole Brown
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
