Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
A
Anonymous Posted on Jul 14, 2014
How can you decrease copper levels?
All levels are great in my 15 x 36 pool, but my copper is always high and my daughter's hair is green. Any advice on how to lower the copper levels. The salt system runs 3 hrs/day and pump runs mosty all day. I boost once/wk.
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Intex Master 1,448 Answers
  • Posted on Aug 09, 2014
David Spradling
Intex Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
530437
Points
1901
Copper levels have to be lowered by delution (adding more water)
your daughters hair rinse with lrmon juice the reason this probably happened your PH and alkalinity are both probably low PH should be between 7.2 and 7.6 alkalinity shouls be between 80 and 120 if un aware of pool chemistry take water to a professional
5 Related Answers
john224
John Prohaska
  • 1378 Answers
  • Posted on Jul 05, 2009
SOURCE: High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Anonymous
  • Posted on Jul 07, 2009
SOURCE: Salty taste, high ph levels, algea and have shocked pool twice
I'm just now setting up my Saltwater generator...so don't have your problem - yet! Local pool guy tho said with the saltwater systems you need to add dry acid to the pool almost weekly to keep the ph down. Sounds like what you're experiencing. The dry acid was cheap and came in small-ish containers, should last long time.
HTH.
Anonymous
  • 297 Answers
  • Posted on Jul 13, 2009
SOURCE: Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Anonymous
  • 297 Answers
  • Posted on Aug 13, 2009
SOURCE: CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Anonymous
  • 8 Answers
  • Posted on Jul 12, 2011
SOURCE: I bought my intex saltwater
did you remember to use cyanuric acid?
Top Intex Pool & Spa Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
