The 5007 has 7 amp channels, so you can set up your main zone to be 5.1 channels and zone 2 to be the remaining 2 channels. Check the manual to see which speaker terminals on the back are connected to which speakers. You will need to go into the setup menu and set the amp for 5.1 + 2 channels. Then you will need to run speaker wires to Zone 2.
I recommend using banana plugs to connect the speaker wires to the 5007. They make a much neater install and eliminate shorts between connections. Sewell Direct makes nice plugs for a very reasonable price.
okay, uh if you havent done anything like changed the password it should be 0000. if not then try the last 4 numbers of your phone number. for example 5007. otherwise i cant help.
check with www.partstore.com and see if you can get a manual for your dvd recorder.i cannot tell off hand what to do the manual will.good luck or go to www.oxysearch.com for transfer of data.
