What can i do when someone has added a partition to my hard drive and than have taken all my original files and made me copies with whatever problems, ir messed up all the files they left me. I don't have a backup disk as they broken in and took it and added what they want to mess it up???? badattitude2011@hughes.net
SOURCE: Hard Drive - Adding 2nd Hard drive
just open the system tower and there you will find a coin cell battery just remove it and put it back
it will reset the BIOS defaults.
for opening your system log on to
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
enter your system model or put in the service tag
you will find a bar coded sticker which has a 7 digit alphanumeric number its either located on the right side of the tower or may be at the back where all the cables are connected
once you reset BIOS do remember to go to system setup again by pressing F2 button at as soon as you power it back on and disable the floopy drive as it will display a message regarding the discket seek failure
SOURCE: Someone was messing with my
there will be reset setting of the monitor find that option and press ok button... it will help you
SOURCE: ntkrnlpa.exe issue
sorry, wish i could help you out, however i dont have any experience with computers what so ever, try resubmitting your request to one of the other experts i am sure one of them will be able to help you.
SOURCE: can't access hard drive getting IDE master hard drive SMS mess
You are getting a SMART error indicating that the hard disk drive is/has failing/failed. Likely, the only way to get data off the drive is to send it to a data recovery center, then install a new hard drive. Data recovery is generally expensive, but if you are interested you can contact places like DRIVESAVERS 800.440.1904
I had this problem while trying to copy all the files in My Documents onto a USB 2gb flash drive. I reformatted the flash drive to fat32 and the problem disappeared. Hope that helps someone else!
