Try this
http://siica.sharpusa.com/product-downloads
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: UX-B800SE Fax
First it would seem as though the default setting may have all been changed. The NO SERVICE message is given because the machine menu setup is not able to comply with present hardware configuration. Such as the menu setup calling for the incoming fax to be forwarded to an email only you have not connected the machine to an internet router.
The most likely thing to do that will fix the fax not being automatically answered is this.
Check this menu setting. Press the <RESOLUTION RECEPTION MODE> Button (with no document in feeder) until AUTO appears in the display to set auto recieve faxes.
This will auto answer a fax after the set number of rings (different menue option). As someone may have changed this it can be from 2 to 5 rings. Note there is also a pseudo ring tone which can also be set although this will only ring on the machine itself.
This is in case the machine auto answers then finds the incming call is not a fax and so need to altert you to take the call.
Now this is a very complex machine so CAUTION when using in a doctors surgury. It is capable of BROADCASTING all the faxes to any other fax machine or email adresses either by design or the office 'meddler'.
You should set the SECURITY password option and keep a copy of this safe to avoid unauthorised access or changes which could then forward your faxes to unknown destinations.
You need to take a week off to read the manual as it is not easy to plough through.
Here is a link to the MANUAL also what is laughing called a 'setup guide'. My advice is to first disconnect the phone line, then go through each menu setting the DEFAULT value. Then try it, then change the setting to suit you. This is no ordinary fax machine.
http://www.manualsmania.com/model.php?model=6a539582aaef41608ed1fb531d872ebc5098af39
You will of course want to selct the English language GB version of those listed. Then enter the anti-spam code which will download the PDF documents.
Any problem with this such as the link disapearing then i will redo it.
SOURCE: How do I get the fax memory out of my fax machine
Try unplugging the power cord for 10 seconds.
SOURCE: Printer Error Fax RX in Memory
I found that once I had posted my question I was able to get into the on-line manual, once you move all the way though the pages (it won't let you jump to the end and work backwards) the solution was right there.
Make sure you have a receiving tray. You can live without your sending tray. If you have the receiving tray and it says TRAY OFF thats because its not seated properly onto the frame. Make sure the tray engages the black sensor next to the speaker, also make sure you have paper in both trays to get rid of the OUT OF PAPER error. If the OUT OF PAPER error continues then you have a broken sensor in the upper tray.
SOURCE: Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
