Quantum IBM Autoloader
Type: 3623-2Sx
Problem: Error Code AO 60 and Error Code AO 27
This is basically a device that holds SDLT Tapes for backup purposes.It kept coming up with the above mentioned errors and I really need your expertise and assistance in clarifying whats these errors referring to and how I can fix it.
Thankyou for your time and your kind assistance is much appreciated.
ET
SOURCE: Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
SOURCE: IBM Autoloader 36232sx error code A027 & A060
A0= Error occurred during carousel movement (position not found). Could be caused by a carousel motor power issue, a missing or misaligned cartridge carrier, an obstruction, or an unexpected cartridge in the carousel path.
I also advise you to update the FW of the loader.
Are you having tapes get "Stuck" in the unit?
Testimonial: "Thanks for the helpful tip, it really help me fix my problem."
SOURCE: HP StorageWorks 1/8 Tape Autoloader
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
