HI is your iphone asking for restriction code once you insert your sim in it then it mean your iphone is locked to some other network provider due to this it wont accept your sim until you unlock it ...You can easily unlock your iphone using sites like OnlineGSMUnlock.com here they are rendering remote unlocking service to unlock all mode iphone from network lock .You first check that whether the service is available for your country and network provider .If yes then pay for it and unlock your iphone then freely use it with any GSM sim ...
SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
SOURCE: locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad?
To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK
button. You can set your phone to lock the keypad immediately, or
automatically if no key is pressed after 30 seconds, 1 minute, or 5
minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
SOURCE: My nokia 6300 says phone restricted
Your phone is locked with the service provider, either you have to flash it or you have to get it unlocked from the Virgin
SOURCE: samsung sch-r450, i need the 4-digit code to
try dialing #43574357* it should show you the sid meid min etc. make sure you write down SID. then go to settings from the main menu>press *>587846. in the MIN and MDN field put in 10 digit phone number and put in SID exactly the same as you wrote it down so if 0 is the first number be sure to put 0 and the rest of the numbers. the phone will reset and your phone WILL work
dear sir, Hi, I need to unblock my security code. It's a LG CE0168. My IMEI no is 352691-01-906839. pls help
