SOURCE: Sharp cd-c3800 cd player jammed
you have defective mechanical CD Chamber, and mechanical Switch, or sensors under the CD chamber.
SOURCE: sharp cd-c472
I did solve the problem; instead of spending time online looking for a user's book, I tore my house apart and found the original one. Thank you for your response.
To set the clock for the Sharp CD-C472:
1. Power switch off
2. Press CLOCK button.
3. Within 3 seconds, press MEMORY/SET button.
4. Press TUNING/TIME to select time mode (12 or 24 hour)
5. Press MEMORY/SET button.
6. Press TUNING/TIME to select hour.
7. Press MEMORY/SET button.
8. Press TUNING/TIME to adjust minutes.
9. Press MEMORY/SET button.
Please note, your "solution is valid for" choice forced the Sharp CD-C401 selection BUT THAT IS NOT ACCURATE THIS SOLUTION IS SPECIFIC TO THE CD-C472.
SOURCE: Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
SOURCE: My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
SOURCE: sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
