Bose Ps28 / Ps48 Series I Acoustimass Subwoofer Speaker Driver Part 256765 Logo
A
Anonymous Posted on Aug 30, 2014
Bose repairs PS28 III powered speaker .Cut off sound after about 30 seconds of turning on the System......Blinking orange and green light on the subwoofer
5 Related Answers
A
Anonymous
  • Posted on Dec 22, 2007
SOURCE: No power to the Acoustimass bass
Hi, have you checked the internal fuse in your sub?
Anonymous
  • 71 Answers
  • Posted on Dec 10, 2008
SOURCE: Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Anonymous
  • Posted on Jan 16, 2009
SOURCE: blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
Anonymous
  • Posted on Mar 01, 2009
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Anonymous
  • Posted on May 31, 2010
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
