Radio Communications Logo
C
Craig Mac Donald Posted on Sep 10, 2014
How to program
I do not have the cd that is needed to program the Keruier K928
  • Craig Mac Donald
    Craig Mac Donald Sep 10, 2014
    help ?
  • Craig MacDonald
    Craig MacDonald May 07, 2017
    I have a C/D if U would like to borrow & copy it !
Mike Fusco
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 16, 2016
Mike Fusco
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
590
Points
6
I have tried chirp for the Keruier K928 it dosent work
Graham Dalglish
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 31, 2015
Graham Dalglish
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1212
Points
You will need the programming cable and a computer. The cable is a USB serial interface lead that plugs into the speaker microphone socket. You will need to get familiar with a program called CHIRP.
REMEMBER, PROGRAM ONLY CHANNELS YOU HAVE A LICENCE TO TRANSMIT ON (CLASS LICENCE FOR UHF CB) OTHERS CAN BE PROGRAMMED FOR LISTENING ONLY.
Testimonial: "KB1LLS i have the cable i do not have the software for the K928 !"
  • Graham Dalglish
    Graham Dalglish Feb 02, 2015
    Download CHIRP and make sure your radio's memory can be downloaded using Chirp. Make sure your computer is properly connected, checking the appropriate port.
Programming a keruier k928 radio
I have the C/D if you would like to copy it !
I will need to mail it, US Mail, doesn't work on email !
mrtiptop1943@aol.com
1helpful
Howto program Kreuier K928
sounds like you are having a problem with your computer and not necessarily your scanner
Can u help me program my K929 Keruier radio ?
Get on Utube using very specific search terms for programming the phone. Or get online and download the owner's manual and it will take you through it step by step.
Nov 26, 2014 • Cell Phones
Need to Download Belkin Setup Assistant
I would suggest the following:
in another computer attempt tocreate an image file of your driver cd as you mentioned you still haveit (I strongly suggest you don't lose it), then with a usb thumb drivemove that image into the computer where you want to run the wizard (the one that does not have the cd drive working). now for you to create an image iso file on the othercomputer (virtual image of your cd) you need nero or magiciso oranother program to create iso files from a cd, now to read that imageon your cd-trayless computer you can use a program called magic disc.
there are other programs you can use to make iso image files that are free
free alternatives to nero
magic disc
- this is free and it will create a virtual cd drive on your computerwithout cd drive, you just need to mount the iso file you created withthe other programs and it will work like a cd drive so you caninstallation cd without ever inserting the actual cd.
good luck!
1helpful
2answers
DISC DRIVER BROKEN ,NEED TO PROGRAM WEBCAM TO PC
I was trying to help getting the drivers online but for that camera it seems to be tricky.
in another computer attempt to create an image file of your driver cd as you mentioned you still have it (I strongly suggest you don't lose it), then with a usb thumb drive move that image into the vista computer (the one that does not have the disc tray working). now for you to create a image iso file on the other computer (virtual image of your cd) you need nero or magiciso or another program to create iso files from a cd, now to read that image on your cd-trayless computer you can use a program called magic disc.
magic disc
- this is free and it will create a virtual cd drive on your computer without cd tray, you just need to mount the iso file you created with the other programs and it will work like a cd drive so you can installation cd without ever inserting the actual cd.
good luck!
CD/DVD drive will not recognize the CD
Try other CD's that you have and see if it read those or automatically run. If you tried other CDs and they can be read then it maybe you may have to inspect your Printmaster CD for scratches or clean it off if dirty. If your CD Rom doesnt read Any CD at all then maybe it may need a little cleaning inside or that you may need to replace it.
2answers
Dvd combo
Did you try axcessing the drive manually ??? Start > My computer > D:(you cd drive),, If it doesnt show up then the drive may be damamged. If it does you just need to associate the .ext with a program. Double click on the drive if a option box doesnt open up, you should see the audio files.. just right click on one and select properties. You should see the program the file is associated with. Just click change and select another program.
Top Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Radio Communication Expert? Answer questions, earn points and help others
