Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code C-1180?
My printer is Konica Minolta bizhub C-1180 what is error code C-1180?
Norman Weimar
Level 3:
  • Minolta Master 7,080 Answers
  • Posted on Dec 28, 2014
Norman Weimar
Minolta Master
Level 3:
Answers
7080
Questions
Helped
1997807
Points
12012
What is the model? Bizhub 180???? with a C-1180 error code could not find that code in service manual, please check again
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 141 Answers
  • Posted on Apr 15, 2008
SOURCE: konica-minolta error code c0012
What is the model ????
Anonymous
  • 7 Answers
  • Posted on Aug 22, 2009
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Anonymous
  • 7 Answers
SOURCE: Job error code on a
is this when trying to scan be more specific
Anonymous
  • 944 Answers
  • Posted on Aug 27, 2010
SOURCE: Just received a Minolta Bizhub
Check if you have your optic mirrors clean, as well as the lamp and the CCD lens.The CCD couldn't read the white stripe at power up.
Other possible causes:
- Optics motor
- Bind on any paper tray lift (try the machine with the trays open and close them one at a time if the error disappears)
- Look for a pinched wire in the registration unit.
If not solved please call the Minolta Bizhub customer care.
This error code actually occurs only if there is a problem related to the optics.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Anonymous
  • 24 Answers
  • Posted on Jan 27, 2011
SOURCE: I am using a konica
Press this button in same order and sequence UTILITY-STOP-0-0-STOP-0-1
Where 0 mean zero of keypad then you see the msg "service mode" press down key and go to ADJUST and press OK press down key and go to ATDC and press OK check the value and increase some higher point again press OK press reset switch off and after some seconds switch on perform above actions until you get machine in ok condition or other otherwise you must be change the developer powder. but be sure to run atdc auto adjustment which is in SERVICE MODE-FUNCTION-ATDC AUTO ADJUST then press ok and leave the machine for complication his process,
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
