Frigidaire ATF6000ES Front Load Washer Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E10 error - Frigidaire ATF6000ES Front Load Washer
Mukesh Kumar
Level 3:
  • Master 3,230 Answers
  • Posted on Aug 09, 2009
Mukesh Kumar
Master
Level 3:
Answers
3230
Questions
0
Helped
913399
Points
9208
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
E11 - Fill time too long. (See test 1 below)
E13 - Water leak in the tub or air leak in the air bell. (See test 2 below)
E14 - Dispenser drawer reed switch is open. (See test 3 below)
To recall the specific fault code from this group, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause/Cancel buttons simultaneously
All LEDs will go blank and after a few seconds the control will signal the stored code
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
Good Luck!!
Thanks
E10 error code. What does that mean?
All depends.
All question need 'make model (what it is)'. Otherwise it is a guessing game. Question was in Audio Players, so moved to Misc.
E10 - Water supply is slow or insufficient. This error will be displayed when the unit senses that the water supply is insufficient and is taking too long to fill the tub with water.
Jun 10, 2016
My EdgeStar Combo Washer / Dryer is displaying an E10 ...
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
KENMORE ELITE FRONT LOAD WASHER, NO DISPLAY IS ON AND WHEN YOU PUSH THE START BUTTON IT JUST BEEPS ONCE and that is it. Thanks Craig..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1helpful
Whirlpool duet dryer-error code e-1?
Not possible actualization firmware E10
Device may require on-line firmware upgrade. Try updating firmware while connected to Internet.
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
