HP Compaq Presario V2000 Notebook Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the same problem with the same computer.
Its overheating
superdave1
Level 2:
  • Expert 156 Answers
  • Posted on Jul 06, 2009
superdave1
Expert
Level 2:
Answers
156
Questions
0
Helped
58305
Points
403
Is the fan turning? If it is, blow out the intake and fan area with high powered air from an air compressor. You'll be surprised how dirty they get. Hope this fixes it.
1helpful
5answers
Fix an overheating buick rendezvous 2002. Truly overheated once, then had the radiator flushed and replaced, along with thermostat (twice) and water pump. Now, the computer indicates it is overheating
You have a needle in a haystack because so many things can cause your problem. I am leaning toward the main computer - which you can replace yourself for around $300. There are companies on the internet that will send you your pre-programmed computer, you have to supply your VIN number. Like many internet companies I always recommend that you are careful in your selection. Be careful to find a reliable company and call them on the phone to make sure they are a real company. If they do not have a phone number - find a different company.
Here are a couple things to try first:
1) Coolant sensor - but this usually makes your car run really poor because it can change the gas/air ratio. If your car is running great other than the overheating sensor - then this probably is not the problem. But worth checking.
2) Serpentine Belt - sometimes when you change the serpentine belt you can put it back on the pulleys out of order. Your car can run great but can cause overheating especially if you have the water pump turning backwards. Since you had the water pump changed you might just take a look at the belt to make sure it is wound correctly. There should be a sticker under the hood.
All said -- I am still leaning toward the main computer.
tip
Tips to secure your computer from overheatingTips to secure your computer from...
<span>There are some simple ways that make you aware about your problem regarding computer overheating.</span><br /> <br /><span><br /></span><br /><span>1. </span><span>The Cabinet fan and processor fan inside the system keeps the computer cool and free from dust. So keep these fans working on.</span><span><br /></span><br /><span><br /></span><br /><span>2. </span><span>Always keep your computer clean inside for stop a computer from overheating. </span><span><br /></span><br /><span><br /></span><br /><span>3. </span><span>For stop your computer from overheating always put it to sleep mode when it's not going to be in use.</span><span><br /></span><br /><span><br /></span><br /><span>4. </span><span>If you are using a laptop, you can prevent it from overheating by purchasing a cooling pad, and do not put it on a restricting surface like your pillow or bed.</span><span><br /></span><br /><span><br /></span><br /><span>5. </span><span>Always try to put your computer in cool place from preventing from overheating.</span><span><br /></span><br /><span><br /></span><br /><span>These steps will prevent your computer from overheating successfully.</span><br /><span><br /></span>
on Dec 24, 2010 • Computers & Internet
tip
How to prevent laptop and Deskto from overheating.
overheating[overheating]"overheating""best computers""computers laptop"
First of all you need to keep your work space clean at all times so that dust and debris do not get into your unit.
Also you need to maintain airflow a routine maintenance of your machine will keep the unit in order.
If you computer is overheating first thing you do is open the case and clean out the dust.
Also you need to replace the Thermal compound under you heat sync where you cpu is.
  1. First you want to do is take off the cpu fan.
  2. Then you want to wipe the access thermal compound off.
  3. Then you apply the thermal compound by adding one dime size drop in the middle of the cpu (do not spread with fingers)
  4. Then you want to put back on your fan and heat sync.
This will keep your system at normal operating temperatures I would suggest you do this once ever 3 months at the most.
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger
on Dec 02, 2009 • Computers & Internet
I sent in my computer a compaq CQ60-615DX two months ago to be fixed. It came back working but is now overheating in the front of the computer. The fan is running and the back is not overheated just the...
You should call up Compaq and tell them that when you recieved your computer, it was overheating. They will most likely ask you to send it back. Sounds like they may have covered up the fan with a ribbon cable or something.
Thanks, Nathan Taylor
2answers
Turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
1helpful
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Memory chip set.
If you have overheated the computer you may have already done your damage to the mainboard. It may be time to replace the main board if it has been overheated. The CPU could have been overheated and damaged.
3answers
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
2answers
Overheating
If you?re not sure if your computer is overheating and you don?t want to check manually, you can use one of the monitoring softwares that check that for you. (for example- ASUS PROBE 2 which came with my motherboard).
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
