HP LaserJet 4100 Printer Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer shows 41.2 errors - HP LaserJet 4100 Printer
Anonymous
Level 2:
Sergeant:
  • Expert 220 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
220
Questions
0
Helped
89757
Points
738
Hope it helps
1. A temporary printing error has occurred.
2. Press GO. The page containing the error will automatically be reprinted.
3. Reseat the connections to the laser scanner and then to the engine controller board.
4. Replace the laser scanner.
5. Replace the engine controller board.
Tim Kelly
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 27, 2013
Tim Kelly
Contributor
Level 1:
New Friend:
Answers
16
Questions
Helped
3386
Points
36
Since when do laser printers have printheads? Do you mean the laser scanner assy? in that case you should get hp parts as this post is about an HP laserjet 4100 printer.
3 Related Answers
Anonymous
  • 561 Answers
  • Posted on Jan 10, 2010
SOURCE: yohoo
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usually just after warranty has expired!
Anonymous
  • 561 Answers
SOURCE: printer- mechanical error 41
Anonymous
  • 832 Answers
  • Posted on Oct 14, 2007
SOURCE: BRother printer error code 41
The printhead is defective. Call brother hotline. Because this is a very common error (due to malconstruction on the mfc 3820 ) they might replace it for free. And when asked: OF COURSE YOU HAD ALWAYS RUN THE UNIT BY ORIGINAL INK CARTRIDGES!!!! :-) (take the ink carts out before sending or giving it to a service dealer!)
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Error 41 brother all in one :Performed Print Quality Check Sheet $ times. The test sheets became closer and closer to being 100% correct, then error 41 pops up
Machine error 41 is "defective print head".Try to turn off the printer and wait 10 min.Then turn on, if the error continue showing your printer need service.
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Error e5 showing
Step 1 : Push Power switch by continue (Tekan Power On/Off)
Step 2 : inserrt plug(Masukan Power, Power Tetap di Tekan)
step 3 : Tekan Tombol Reset 1x, lepaskan Tombol Pwr, Tekan Reset dua kali lagi Sampai Menjadi 0 (tekan tombol tanpa jeda)
Step 4 : Push + display change from 0 to 1 (tekan tombol + untuk merubah 0 ke 1)
Step 5 : Push Power switch again , Printer will be print 1 page(tekan tombol power –> tombol start sampai ngeprint 1 hal.)
step 6 : Open cover (buka tutup printer)
Step 7 : Unplug (cabut kabel power)
Step 8 : Take out ink 40 and 41(lepaskan catridge 40 dan 41)
Step 9 : Insert plug again (pasang kabel power)
Step 10 : Push power switch (tekan tombol power)
Step 11 : Open cover (scan cover) (buka tutup scaner)
Step 12 : Inksert ink 40 , 41 again (masukan catridge 40 dan 41)
1helpful
Yohoo
Brother Machine Code 41
error 41: ph is defective and needs replacement.
Printer- mechanical error 41
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
