How do I reset the water heater with an error code?
SOURCE: Keep getting error codes and have to reset too often
This paticular problem your having is specific to the jumper in the heater. The jumper is for condensing heaters. Your heater does not have the specific wiring or computer for condensing. So they added a jumper in the wiring. It is failed or failing. It should ohm out at about 120ohms. sometimes its just a loose connection. Check this out, and called 1-800-642-3111, they have been very busy, but leave them a message and they will call you back.
SOURCE: A2 error on Bosch tankless water heater
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q.
FA - Gas leakage error, gas valve circuit not closing properly
A.
Q.
EA - No flame ionization detected with water flow
A.
Q.
C1 - Fan rotation too low on startup
A.
SOURCE: i AM GETTING AN A2 ERROR CODE
hi ill try to help the fault is in the overheat cutoff fuse its the white overheat wire fuse that wraps around the heat exchanger disconnect the plug connector between the fuse wire and the control unit ! using a multimeter check the resistance through the fuse to see if its bad !if its bad check to find the cause ie .a leakage of flue gasses on the heatexchanger also check the black rubber seals located at the top and bottom of the heat exchanger also inspect the seal around the viewing window on the heat exchanger then call tec support and report leakage areas also for fuse replacement the only number for tec support i can find is 08006423111 i do hope this helps
SOURCE: Bosch Tankless water heater. model AQ 250 SX
Error codes F1 and F2 do not show among common error codes.
Call Bosch 1-800-642-3111
Before calling service technician, open following links for Bosch troubleshoot resources:
Error codes are considered start-point for troubleshoot.
Multiple error codes can indicate PC board failure.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/Troubleshoot/tabid/569/Default.aspx
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
