Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
D
David Frenzel Posted on May 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove Error code 021 - Panasonic Panafax UF-585 Plain Paper Laser Fax
Anand Krishnan
Level 3:
Guru:
  • Master 149 Answers
  • Posted on May 28, 2015
Anand Krishnan
Master
Level 3:
Guru:
Answers
149
Questions
Helped
44465
Points
2752
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Turboion croc classic flat iron bc-cr1. When I turn on, error code 021 and it shuts off. Is there a fix?
Error code 021 on a Turboion Croc Classic flat iron indicates a problem with the temperature sensor. This error can prevent the flat iron from heating up properly and may cause it to shut off unexpectedly.
To fix this issue, you can try the following steps:
  1. Turn off the flat iron and unplug it from the power outlet.
  2. Use a small screwdriver to open the back cover of the flat iron and locate the temperature sensor.
  3. Carefully inspect the temperature sensor for any signs of damage, such as bent or broken wires, loose connections, or burnt components.
  4. If you notice any damage to the temperature sensor, you will need to replace it with a new one. You can purchase a replacement temperature sensor from Turboion or from a third-party supplier.
  5. Once you have installed the new temperature sensor, reassemble the flat iron and plug it in. Turn it on and check if the error code 021 is still appearing.
  6. If the error code persists, you may need to contact Turboion customer support for further assistance. They will be able to provide you with more detailed troubleshooting steps and help you resolve the issue.
Dec 04, 2022 • Irons
I have a allince cap32hp and its showing an e7 error code what shoeld i do to make it work
That's a South African Company and you will need to call the support number they don't list the error codes in the manual I have, sorry.
Cape Town: (021) 556-8292
1helpful
2answers
We are getting Error CODE 021 on our fax machine Panafax UF-560 and can't find the owners manual to fix it...can you help?
Error code 021 indicates a bad fuser but in some cases, the error can be reset. To attempt a reset, do the following:
  1. Remove the toner cartridge and close door back up.
  2. Power down the fax (switch is on the back side lower left) for 5-10 seconds.
  3. Power on the fax and see if the 021 code is gone.
  4. Re-insert toner cartridge
If this doesn't work, there's one other thing to try prior to calling a technician.
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax
If this doesn't work, a service call will be needed to replace the fuser. I do hope this fixes your problem.
(reset information courtesy of Eliot at howtomendit.com)
13helpful
3answers
Error code 021
Press
Function
7
6
set
I have a panosonic uf-4000 fax it keep reading error 021. It is not listed in the book. What does this code mean
021 is a fuser error, that can either be reset in service mode or i may need a part in the fuser. Best to call a local service rep.
4helpful
3answers
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
2answers
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
