Jitendra Vyas Posted on May 07, 2017
How to setup scan to email without computer for Brother Printer MFC 7860 DW?
I have Brother Printer MFC 7860 DW and I want to scan documents from its scanner and send the scan directly to given email address, without using the computer again after setting up everything. I have upgraded the latest Firmware. I'm on OSX. I have these options but I don't know how to configure them. I just want get scans on an email. Can anyone help me what to fill here to get Scans on my personal gmail address? http://i.stack.imgur.com/BLAoU.jpg
3 Related Answers
Anonymous
  • 63 Answers
  • Posted on May 01, 2009
SOURCE: Ricoh 1515 scanning direct to emails
you will need the copier hooked to a network and able to get out to the internet. You will need a email account like comcast.mail.net and password if your mail server has authetication. On the ricoh go to USER TOOLS buttom choose SYSTEM SETTINGS - FILE TRANSFER-SMTP and enter the setting there good luck
  • 6751 Answers
  • Posted on Jul 20, 2010
SOURCE: I am trying to figure out how to use my Brother MFC-8440
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Anonymous
  • Posted on Dec 19, 2012
SOURCE: Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
