Dishwashers Logo
l
lise Posted on Sep 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is aquastop
My bosch wont stop running
Chris Hall
Level 3:
President:
  • Master 842 Answers
  • Posted on Sep 23, 2015
Chris Hall
Master
Level 3:
President:
Answers
842
Questions
0
Helped
376910
Points
2776
I presume that when you say it wont stop running, it's the empty pump that is running. This is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
