Music Logo
b
benjamin jacobs Posted on Oct 20, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is samba
Drums
rhodesworks
Level 3:
Top Expert:
  • Music Master 3,159 Answers
  • Posted on Oct 21, 2015
rhodesworks
Music Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
582045
Points
331464
Samba is a latin rhythm and dance.
How do i build other drumset on the hds110usb module, also how do i chaange volume on individual drums
To build a custom drum set and adjust volume on individual drums using the Alesis HDS-110USB drum module, follow these steps:
Building a Custom Drum Set
  1. Accessing Edit Mode:
    • Turn on your Alesis HDS-110USB module.
    • Press the "Voice" button repeatedly until you reach the desired drum voice you want to modify.
  2. Selecting Drum Voices:
    • Use the arrow buttons (usually labeled with up and down arrows) to navigate through the available drum voices.
  3. Assigning Drums to Pads:
    • Once you find a drum voice you like, press the "Voice" button again to assign it to a pad.
  4. Saving Custom Drum Sets:
    • After assigning voices to pads, you might want to save your custom drum set so you can access it later. To do this, refer to your user manual for the exact procedure as it can vary slightly depending on the model.
Adjusting Volume on Individual Drums
  1. Accessing Volume Controls:
    • To adjust the volume of individual drums, you typically need to enter a specific editing mode. On the Alesis HDS-110USB module, this is often done through a combination of button presses while in Edit mode or via a dedicated "Volume" or "Mix" button.
  2. Navigating to Volume Settings:
    • Once in Edit mode or the appropriate setting menu, use the arrow buttons to navigate to the volume setting for the drum you want to adjust.
  3. Adjusting the Volume:
    • Use the dial or arrow buttons to increase or decrease the volume level for that particular drum.
  4. Saving Changes:
    • After making adjustments, ensure to save your changes according to the instructions provided in your user manual. This often involves navigating to a "Save" or "Store" option and confirming your changes.
Additional Tips
  • Referencing the User Manual: The exact steps can vary depending on the specific model of your Alesis drum module. Always refer to the user manual for precise instructions tailored to your device.
  • Experimenting: Don't hesitate to experiment with different drum voices and volume settings to find the sound that suits your preferences.
By following these steps and consulting your user manual for any specific details related to your model, you should be able to build custom drum sets and adjust individual drum volumes effectively on your Alesis HDS-110USB drum module.ChatGPTTo build a custom drum set and adjust volume on individual drums using the Alesis HDS-110USB drum module, follow these steps:Building a Custom Drum SetAccessing Edit Mode:Turn on your Alesis HDS-110USB module.Press the "Voice" button repeatedly until you reach the desired drum voice you want to modify.Selecting Drum Voices:Use the arrow buttons (usually labeled with up and down arrows) to navigate through the available drum voices.Assigning Drums to Pads:Once you find a drum voice you like, press the "Voice" button again to assign it to a pad.Saving Custom Drum Sets:After assigning voices to pads, you might want to save your custom drum set so you can access it later. To do this, refer to your user manual for the exact procedure as it can vary slightly depending on the model.Adjusting Volume on Individual DrumsAccessing Volume Controls:To adjust the volume of individual drums, you typically need to enter a specific editing mode. On the Alesis HDS-110USB module, this is often done through a combination of button presses while in Edit mode or via a dedicated "Volume" or "Mix" button.Navigating to Volume Settings:Once in Edit mode or the appropriate setting menu, use the arrow buttons to navigate to the volume setting for the drum you want to adjust.Adjusting the Volume:Use the dial or arrow buttons to increase or decrease the volume level for that particular drum.Saving Changes:After making adjustments, ensure to save your changes according to the instructions provided in your user manual. This often involves navigating to a "Save" or "Store" option and confirming your changes.Additional TipsReferencing the User Manual: The exact steps can vary depending on the specific model of your Alesis drum module. Always refer to the user manual for precise instructions tailored to your device.Experimenting: Don't hesitate to experiment with different drum voices and volume settings to find the sound that suits your preferences.By following these steps and consulting your user manual for any specific details related to your model, you should be able to build custom drum sets and adjust individual drum volumes effectively on your Alesis HDS-110USB drum module.
Dec 12, 2017 • The Music
1helpful
What song has the lyrics: Call me don't be afraid, just call me and I'll be around (or there) . . .?
The song is "Call Me" and was recorded by a number of diffrent singers, mainly female (Petula Clark, Nancy Sinatra, etc) but males as well (Frankie Valli). It was used as a lot as an album filler. Most arrangements I've run into have a samba beat.
I just bought this kit and I'm watching the DVD Drumset 101 that came with it and it starts by saying to "lower" the bass drum spikes. They aren't even attached, I don't even know...
The "spikes" are the legs near the backside of the drum that keep it from rotating... Some actually have spikes that go into sockets and dig into the floor under the drum. The photo shows the legs. The drum pedal may have spikes and or a clip/clamp that grabs the nearside of the bass rim to keep the pedal from pushing the drum away.
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
I have the Simmons SD7PK. It sounds as though the speakers to my amp or through our PA system are busted. What could be causing this?
First thing is to verify your sound system is OK by running program material such as a CD at normal levels through it. If it is OK then you need to consider if your drum set is overdriving your sound system. Drums generate high pulses and can easily saturate PA systems. First thing here is to connect headphones to your drum set and listen how the set sounds via headphones. If both these tests pass muster, then your PA system may be too small to handle the drum audio. In that case, get at least a 15 inch powered monitor, preferably bi-amped to run the drums through.
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
I need to aassemble a Snare Drum that has been dismantled.
Try here:http://www.ehow.com/video_2379338_replacing-snare-drum-head.html or here:http://www.youtube.com/watch?v=twHxMISI7hg orhttp://www.remo.com/portal/pages/drumming/product_tips/Drumming+Product+Tips+Tuning+Concepts4.html
Oct 13, 2009 • Music
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
1helpful
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 • Music
3helpful
Where to connect 3rd cymbal cable end to drum machine
well i am not sure what r u talking about,but as i met the same problem,i assume that you mean you lack one cable...What you should do is:
1.Connect the cable to the cymbal.Then connect it the ending of the cable with bass drum(not with the device)
2.Connect the bass drum with the device,as there will be 2 cables in the bass drum.Then plug it into the device & you will be ok.
Top Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Music Expert? Answer questions, earn points and help others
