Air Purifiers Logo
A
Anonymous Posted on Oct 25, 2015
Does it really purify,drain and restore your entire lymphatic system?
Nativ Sens
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Jul 06, 2022
Nativ Sens
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
6
Questions
0
Helped
2672
Points
16
Gua shas are most frequently used to treat muscle and joint pain, but they may also help with (breathe deeply): reducing inflammation, brightening the complexion, reducing dark circles, Gua Sha lymphatic drainage, decreasing puffiness, softening fine lines and wrinkles, lessening scars, contouring the face, and assisting product absorption. It isn't merely referred to as "the Botox of the Far East."
Bill Boyd
Level 3:
Top Expert:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Air Purifiers Master 53,816 Answers
  • Posted on Oct 25, 2015
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
12331554
Points
172813
Nothing does that
if it was possible then there would be no cancers in the lymphatic nodes and cancer would be obsolete as all that would have to done is to drain the nodes
just good but deceptive advertising
Rainmate Air Purifier. Why does my Rainmate not mist?
Question edited for clarity and correct maker name, plus (what it is).
Question moved from Cars and Trucks.
Usually just need cleaning and descaling
Cleaning Tips
Rainbow System https://rainbowsystem.com > Support
You can even fill the Sprayer with ordinary household water and use it to mist your houseplants or clean your screen windows.
The Rainbow Rainmate: Does It Really Work?
GroundWaterGovernance.org https://www.groundwatergovernance.org > does-the-ra...
Mar 13, 2022 - The simplest solution appears to be to change the water on a regular basis if possible. A home air purifier can be used as an aromatherapy ...
I have an E1 error message on my Idylis 400 square foot air conditioner. There is no water in the system.
Add the water in the system and see what happens, Even a horse needs water to work. I take it your unit is an evaporative A/C. I have a Penguin water assisted A/C, of which I have to fill a large plastic container then load it in the unit and start the A/C. It cools well but doesn't really cool like a wall A/C. But it's better than nothing.
Is the air coming out the front supposed to be angled to the right or is is supposed to pour out the entire front?
Hi Allan,
Here's the Holmes service/support page. I am certain they can answer the questions regarding your air purifier.
PEACE
How do i clean the eco-quest air purifier? Mine is the Breeze AT model.
take the back filter off and blow out the dust really well a q_tip may help with the tight spaces that will be a very tedious task check owners manual too
The Living Air O3 purifyer has stopped producing the purified air. The contact panels (2) have been clean as well has the entire unit on the inside. Fan runs and the little orange light is on in the...
Wow, the purifying plates have been is use for over 8 years! I think that your problem, try a new set of plates. You can contact the company at 800 989 2299 to order some new ones. Or you can email me stevelam at ecobusiness dot com and I can help you get some plates. Hope this helps.
IS THIS PURIFIER REALLY WORKING IS IT a hepa or carbon filter?
Most particles in the air are neutral in charge. Meaning they have the same amount of negatively charged electrons, and positively charged protons. A common type of air purifier uses what is called corona discharge air purifier. These type of air purifier create molecules called ions. When particles pass through these air purifiers electric current makes these particle either positively charged or negatively charged. Once these "ionized" particles from the air makes contact with objects that are opposite of thier charged, they stick to them instead of lingering in the air, or they may clump with other particle untill they are too heavy and fall to the ground. Filter types air purifier are not so good since they require periodic filter replacement. These type of air purifier are usually part of the air conditioning system. The purifier picture I see are the ones i just mentioned, and they are not filter types.
Message says Replace Plate
Pat,
the circuit board might be the issue here. There is another possibility.
Sometimes the contacts that connect to the place do not make good contact. You can try to carefully bend the contacts after removing the plate to create a tighter fit. Be careful not to move/force the little bar where the contacts are connected to.
Cleaning the contacts with denaturalized alcohol might work too.
Hope this helps!
Eric
2helpful
My Fan on My Flair purifier is not turning when I turn on the unit. Nervous about poking around in there don't want to break it, any ideas how to fix this? Thanks
To fix it..........there is one screw on the unit on the outside.........really long!.......remove that and the entire unit just slides out of the housing..........
The replacement fan motor can be purchased on ebay....ranging from $21.95 to $32.95...depending on the model Flair that you have...the most common one is the $29.95 replacement...
Really quite simple to remove and replace!!! and well worth it!
Hope this helps.
Top Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you an Air Purifier Expert? Answer questions, earn points and help others
