IBM ThinkPad A21m 2628 Notebook Logo
Posted on Jul 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Post problem 0175 Bad CRC1 stop post task
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Jul 15, 2009
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
26849
Points
285
If it beeps (which it should) means that some device did not pass post. Find your motherboard online and look up the beep codes. This should help you to discover the problem. I hope this helps!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 02, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
495
Points
0175 bad crc1 stop post task
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jul 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4028
Points
7
3 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Aug 07, 2007
SOURCE: stop POST task, bad CRC1 error 0175
There are a couple of possibilities, go to this link for the solutions, but it could be a bad power supply http://www.hardwareanalysis.com/content/topic/31761/
Anonymous
  • 68 Answers
  • Posted on Oct 07, 2008
SOURCE: while booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Anonymous
  • Posted on Apr 28, 2012
SOURCE: 0175: bad crc1, stop post task, system bios shadowed
pls read it.http://www.amiragroup.co.in/karan chanana-potter
4helpful
ERROR 0175: bad crc1, stop post task
0175: bad crc1, stop post task ,ibm t20
2helpful
5helpful
2answers
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
ERROR 0175 BAD CRC1 COMMAND STOP POST TASK
the crc is the cyclic redundance check your bios is corrupt. you will need to flash the bios to bring it back the internal bios bottery will need to be removed for 1 min then replace. it should bring it back if not you bios chip has burnt out. i have never replaced a bios chip but you will have to find one to replace it
2helpful
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
2helpful
Error 0175 on boot IBM Thinkpad T20
Error code Symptom or error Field replaceable unit or action, in sequence 0175 Bad CRC1, stop POST task. The EEPROM checksum is not correct. System board
2answers
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
1helpful
While booting error " bios shadowed " & 0175: bad crc1, stop post task
T20 Would not Get past Post
Looks like a bad RAM chip or HD...
1helpful
Stop POST task, bad CRC1 error 0175
Top IBM Computers & Internet Experts
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
