SOURCE: forgot password to htc hero the google password
format the phone... download the firmware frm the HTC site and follow the instructions
SOURCE: On a Samsung GT19000, I
As you said,
> Menu (Home Key) > Applications > Settings > Location and Security > Require Pattern
< Screen Unlock Pattern check box should be selectable or de-selectable. But if this doesn't work, then there's must be something wrong with the system files, like software/o.s corrupted, or some other applications already deactivated or some malwares have infected. It could be Java script problem as well, since almost all the programs/applications/features are running through Java.
The only possible trick you can try is "Phone Reset" but be sure, data saved on your phone will be lost at every reset attempt. There are several reset and all reset codes don't work on all models. I am giving you the most common codes:
Hard Reset Codes:
*2767*688# or *2767*2878#
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Good luck.
Thanks for using FixYa.
SOURCE: I have locked my Huawei Ascend with the pattern
Tounlock cell phone Password:Instructions
Things You'llNeed:
Enter the last fourdigits of your phone number on your cell phone PIN screen.
Enter 9999, and if thatdoesn't work try 1111, and if that doesn't work try other 4 digit numbers youmay have entered.
Shut off your cell phone,take off the back of your phone and pull out the battery. Record the IMEInumber which is under the battery. Re-insert the battery and power on thephone. Enter the last 4 digits of the IMEI number on the PIN entry screen.
Call your serviceprovider and request the unlock PIN. You will have to prove you are a customerby stating your cell phone number, address and social security number.
Turn off your phone. Holdthe keys "3," "*" and "Call" and switch the phoneon. Hold the three buttons down until the word "Formatting..."appears on the screen. This should reset the phone lock code.
